What Did You Do with Your 80 This Weekend? (69 Viewers)
A year later and I still remember that post. That's a classic.
Admittedly it is where I get my "Tommy Bahama" line I drop on every person that asks the 80v100 question. I didn't remember where it came from. I will have to properly cite @zona in the future.
Over the last few weeks I started to have intermittent no starts. I would turn the key and get a click but nothing else. After 3-7 tries it would finally turn over and start. Replacing my power and ground cables was already on my radar so I went ahead and replaced the cables from the battery to the starter and the battery to engine ground with #1 welding cable. So far it starts every time without hesitation.
No crimping, just solder. There are various opinions about this but a lot of racing forums said just soldering is fine. Time will tell. I still need to do the alternator cable but wasn't 100% sure where it ran after going into the loom. I think it connects to the fusible link???
While moving things out of my way I noticed this.
I wire brushed it the best I could and scraped out what I could from the ignition coil. Added some dielectric grease and plugged it back in. Can I buy a replacement cable or do I need to buy the whole set? Also figured out my FR wheel is loose from 12-6. Time to check the bearings... Also ordered some Philips HIR bulbs.
View attachment 1345739 View attachment 1345738
Whole set. Its in your best interest to do all anyway.
At least he can probably rule out needing a new distributor since he doesn't have oil in the cap!
Not the weekend but soon will be......So replaced my center console with this freezer a while back - Got to say am pretty impressed with its capacity.
Few buddies and I heading out on week long adventure soon....
To give an idea of volume - That's 10 chicken drumsticks, 12 lamb cutlets, 2lb salmon, 2lb ribeye, 1lb mince, 1lb carne, 4 burgers - all now being frozen :-)
Voila!
Mudder came by needing help. He needed his timing to be 3* so he can get it smogged. 5 mins later and was good to go. But he was complaining about his PO170. I told him it's always vacuum related so just check all of the vacuum hoses and replace one by one. He then says his exhaust smells different lately...sweeter.
"For your sake I hope not!"
He starts the truck and I do a quick visual check. It's fine. Nothing obvious and the exhaust just smells less like unburned fuel. Then he drops the last tigbit of info:
"The CEL only goes on when I have to brake hard."
*Eureka moment*
I said, "it's a leaking check valve, booster or hose". Quick check and yup, there was a long horizontal tear in the hose after the clamp coming from the intake on its way to the booster. Everytime he brakes hard the motor shifts forward. Forward enough to pull on the hose and cause the vacuum leak.
Problem was though I didn't have a spare booster hose. Cutting his hose to remove the split made it too short and useless. As it turned out the smaller power steering hose I carry is not only the same I.D. but the exact same length. Bam! He now has an emergency hose as a spare when he replaces it finally.
Oh and CEL is gone ;)
To give an idea of volume - That's 10 chicken drumsticks, 12 lamb cutlets, 2lb salmon, 2lb ribeye, 1lb mince, 1lb carne, 4 burgers - all now being frozen :)
Voila!
What model is this exactly?
Voila!
Can we see it in position in yer 80?
*Eureka moment*
What?! No duct tape? I am disappointed.
its the dometic cdf11
also photo @Lefty3247, @dcguillory
can grab more pics later (@Ocho77 has more pics on one of his threads somewhere).
it was an expensive solution for the cupholder/armrest problem- the fact i got a fridge/freezer was an added bonus........
  • lin
