Early start to the weekend. Cold camping in the Sierras.
Did you do the flare removal yourself? This would be my numero uno wishlist item but it seems like such a PITA.It was strongly considered, but decided to keep it to manage negative pressure on the rear to combat rain and dust buildup.
Flair removal was straight forward, just unbolt and unclip. Even doing it by hand I had a couple of those nut inserts break but wasn’t a big deal since they weren’t going back on.Did you do the flare removal yourself? This would be my numero uno wishlist item but it seems like such a PITA.
While some will acert that welding is the only way to fill the holes. I would beg to differ. I weld, have all the equipment, weld well and I still chose to fill the holes with fiberglass impregnated Bondo. I also did this when I remover the roof rack. I have had zero issue using this method. you don't have worry about rust issue where you can't get to the inside to repaint after the welding burns off the paint. I was also able to get the roof rack removal done without removing the the head linerFlair delete isn’t hard if you can weld. Just remove the flairs, drill rivets. Weld, grind paint etc.
The roof is another animal that I did not do.
I'm glade that your no start issues are gone ! My rig sets for weeks to a month or more at a time without the issues you speak ofgooseberry mesa - start of a 3-6 month road trip west of the rockies!
i had been hunting an intermittent non start issue - over last few years the 80 was driven once or twice every 2 weeks.......checked input voltage to starter motor that was fine (so no relay bypass needed), load tested battery that was fine - now I'm driving it every day no issues at all (and the reman yota starter i bought now gets lugged around with me.....hey ho!)
Also the wolfbox tri pro dashcam i installed is no longer cutting out randomnly - seems these trucks dont like sitting around waiting to be driven!
Had to replce the charcola cannister - got 8 or so years out of the last one!View attachment 4008860
The fiberglass Bondo is water proof has epoxy in it and if done correctly just does not fall out. I did mine 9 years ago and not one hole has popped out.
What cannister is that ? part number ?
Love that area. Took a 93 Range Rover there about 18 years agoNow my son’s daily. Got a chance to take it out with him for some light Okie wheelin at Gruber ORV. Pretty fun little spot. You forget how capable these things are when you haven’t had them in their element for a bit.View attachment 4009022
Fiberglass Bondo and regular Bondo are not the same.Def not the only way. Use this for the inside to protect from rust after welding.
Amazon.com: U-POL UPol WELD/AL WELD-2 353 g/12 Oz Zinc Rich Primer - Grey/green : Tools & Home Improvement
Buy U-POL UPol WELD/AL WELD-2 353 g/12 Oz Zinc Rich Primer - Grey/green: Primer - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I’ll never use fiberglass ever, and I’ll leave it at that, but good to have options.I would guess that most people use bondo to fill those.
Have you ever tried the fiberglass stuff ?
And some of the holes you can’t get to the back to paint
Not having to remove the head liner to do a roof rack delete is a huge plus.
If you’re going to weld the holes you will be removing it.
That would be the Eastern Sierra/Inyo/White mountains, my Mecca.What part of the country is this?
Or just some auto zone bulk gasket material. I might actually have a couple but I would have to check.Manilla file folder. Used this approach multiple times.
Where were you starting to smell gas (and pressure in the tank) at higher elevations?gooseberry mesa - start of a 3-6 month road trip west of the rockies!
yeah - and then when I opened the hood I could hear odd noises coming from the canister for several minutesWhere were you starting to smell gas (and pressure in the tank) at higher elevations?
