What did you do to your pig today? (10 Viewers)
Does he need to chase the moisture out?
Personally I would spray it down with a hose first that way you can see how far the heat spreads. But the main key is as soon as your done you hit it with a hose again so you can paint it sooner without it being exposed to the environment and moisture
Question or guidance from all FJ40 owners, does the headline go directly unto that metal roof? IMO in Houston, Tx the heat is overwhelming and I don't believe the headliner will last very long!
O
On fj55 there's a layer of felt between the headliner and the roof skin.
It helps with the heat of the sun and id put some in your fj40 before the headliner goes up.
I used contact adhesive to stick it to the roof.
Sell it and buy a 55 problem solved..
NO!
Dropped my skidplate. It's a lot easier coming down than going up, thing weighs about 100 pounds. I don't need it around town and it looks like I have some parking brake seals work to do. I'll just lean it up out of the way until the next hardcore run
