Does he need to chase the moisture out?Sounds like it’s time for a LS swap, just make sure you weld those motor mounts in really hot on the vertical welds and you’ll be good to go.
Personally I would spray it down with a hose first that way you can see how far the heat spreads. But the main key is as soon as your done you hit it with a hose again so you can paint it sooner without it being exposed to the environment and moistureDoes he need to chase the moisture out?
I did that once and now she wants child support. its a scamWet Willy![]()
4040 or 55??? If 40 take top off. If 55 put bags O ice on da floor
You’re in the wrong place
Sell it and buy a 55 problem solved..
Question or guidance from all FJ40 owners, does the headline go directly unto that metal roof? IMO in Houston, Tx the heat is overwhelming and I don't believe the headliner will last very long
Thank You!O
On fj55 there's a layer of felt between the headliner and the roof skin.
It helps with the heat of the sun and id put some in your fj40 before the headliner goes up.
I used contact adhesive to stick it to the roof.
Don (FC Fab) make that? Looks a lot like the one I have on my 40, definitely takes a tranny jack to install that heavy bastard!Dropped my skidplate. It's a lot easier coming down than going up, thing weighs about 100 pounds.
No, skid plate came with the doubler from Morgan. Heard that it was a Butch built but don't know for sure.Don (FC Fab) make that? Looks a lot like the one I have on my 40, definitely takes a tranny jack to install that heavy bastard!
