7-pin connector wired and installed:
I hope my trailer wiring is long enough to reach!
I thought I would post some "lessons learned" from the install of this kit:
https://www.etrailer.com/p-ETBC7/Brake-Controller-7--4-Way-Installation-Kit---10-Gauge.html
First, take the 10 gauge wire and lay it out flat in the sun so it is nice and pliable.
Next, drop the spare tire.
Then I would pressure wash the underside of the truck. No one likes dirt falling in their eyes!
Now figure out where the mid-point of the wire run is and crawl under the driver side your 100. Driver side b/c battery is there, brake controller will get wired there, and I put my 7-pin on DS to be away from exhaust side.
Start at the front of the fuel tank. On my LX, there was a hole at the seam in the tank that was perfect for a zip tie. Working my way back you can route the wire between the tank and the mounting strap, then over the cross-member. Keep working your way back and looking for places to route the wire that will keep it out oh harms way. At the back, I put an extra loop of wire in case I ever wanted to move the connector. I zip tied the loop to the fuel inlet pipe, up above the spare.
Now go back to the front of the fuel tank and plan your route forward, and then up to the battery. You want to stay away from the exhaust and the cat. There were some brackets that you can tuck the line over that will keep it in place with the help of some zip ties. Once it comes time to route the cable up. run on the inner fender, stay clear of the brake lines. Run the wire bundle out the top where the inner fender and firewall meet.
Now it is time to remove the outer wrap. This is the best place to do so because the black wire will run up to the battery (via circuit breaker), but the white wire needs to go into the passenger compartment via the rubber boot in the firewall.
I wish I had started at the midpoint of my LX. Instead I started at the back and ran forward. But I kept finding better places to run the wire, so I would have to pull the wire back and start all over. 2 x 10-gauge wires in a bundle are kind of bulky and cumbersome to keep moving around, so this took some time!
Hope this can help someone...
