TTT -- The Tool Thread (9 Viewers)
I need to buy a Pitman Arm Puller and would appreciate your recommendation. Thanks.
If you plan on it being a one time use, autozone tool lending.
they work pretty good, i have a 12 ton, it seems a little on the light side sometimes, but manages to do what i ask of it. pretty easy to move around also. might do a 20-ton if i ever have to replace it.
I've got a harbor freight 20t that I've had for 5 years or so. Bought it to rebuild transfer cases and have found plenty of other uses for it since. Good price, iirc $160 or so.
Thanks, Johnny - I will take you up on that!
I need to get the parts in - will know this AM on timing.
Everything is broken down except for the axle nut that my 400 ft/lb impact won't get off yet :)
Yea! I need some pipe. I left my old cheater bar back with the old house :( Bad move. It had the alternative job of holding up something in my old garage, grr - should have kept it :)
My little 18" 1/2" drive breaker bar will probably break - will try today - its Craftsman LOL
Found this relatively thin-walled chrome bar in my stash of junk. . . it worked, but mf'r nut made me use the cheater the entire time - didn't notice any lock-tite-like stuff, but who knows. Something to worry about next - gotta put it back on :( :)
Impact wrench was a no-go until the final turn almost. Bearing is pretty loose in there. Would love to replace the CV, the LBJ and the Tie Rod end, but am on a budget and I can't say they have failed from the feel of them - - looks are bad, though :) Prolly could use a new UBJ, as well, but . .next time.
Patrick, I have one. Mine is the $20 Trail Gear one that John mentioned. It works great. You are welcome to use it. Just let me know and I will leave it out for you to pick up.
Box of wet wipes and some green label Gold Bond and you are good to go for a couple weeks! :)
Not to bum anyone out, but the Tool Thread is starting to slide. Not in an irritating way and I've dung much worse, just a rash of topics hovering around the ole balloon knot. Butt I digress .......
