When blocks are decked, is it typical that machining marks are made with a kind of cross-hatching? In other words, the tool cuts on both the front and rear side across the length of the block if the milling head is perfectly perpendicular to the axis of travel.
I think I’m following you. Yes, since the cutter spins in a circular motion, it will have slight cut marks from the front & back arc of the circle.
