PabloCruise
- Thread starter
- #81
The idle speed control valve should open up a bit under the compressor load and at least try to keep the engine idling around 650rpm.
FJ62 and FJ80s didn’t cut the a/c off when at idle. The ecu has the ISCV compensate for the load and attempt to keep the idle speed at 650rpm.
I don’t think your ISCV is working properly...
The A/c on signal to ecu from amplifier just raises the desired idle speed to make the a/c system more efficient and blow colder. Compressor spins faster, and fan moves more air over condenser.
Thank you! That helps confirm my suspicions.
Looking forward to your product!
