@2001LC Based on your recommendation, I have checked my bleeder caps, all of which where cracked. I ordered new Toyota bleeder caps and will do a whole brake line flush since it has been a couple of years anyways. My question for you is, do you ever replace the bleeders just as preventative maintenance? If so do you go OEM only or is whatever the local NAPA offers fine too?
I do not replace if they clean up good and seat is not damaged. But if they weep even after I torque a little extra, up to 12IN-lbf. Then I replace with OEM only. That's provided it is an OEM caliper. I see aftermarket bleeders weep to often. I keep some OEM bleeders on hand. Both fronts which are longer and rears just in case. I also keep some used on hand. They come in handy to plug caliper when I pull bleeders to recondition.
Hey Paul,
Thanks for the power steering update. I’ve sub’d all your threads - and follow you now so I can always see what new info you give us. When you’re looking for leaking rack and pinion, the only thing I know to look for is the wetness on the boots. Is there anything else you are looking at? Does the wetness clear up after a while if it’s sealed? Nice butt connectors, at first I was like, oh I hate butt connectors but then I saw they were tyco and I always liked that brand back in the day, looks like good stuff. Did you pick those up online?
Boots, if wet, tend to keep weeping even after leak stops. They just are full of fluid, so takes a long time to dry if ever. So I use reservoir's level as my indicator.
I also look at input shaft. It's common leak point. It's one AT-205 works best on.
Here is a dry input shaft.
Another leak I see about 1 out of 10 inspection. Is the flex hose portion of high pressure line.
I clean really good than watch, just like all leaks. Then tend to weep, so must be watch close.
The very most common leak or weep is from return and suction hoses coming off reservoir. I replace those most often.
Final is leak point is the vane pump (power steering pump) seal at front of pump behind pulley. This one goes and new or rebuilt pump is the cure. I've seen AT-205 slow it, but it comes back and is a bad leak. It's bearing will have play and you can't stop seal from leaking, as it get worn out from play/wobble of out put shaft.
I bought the Tyco wire but splicers from Grainger locally. They are great. Some mud members pointed them out to years ago. My heat gun is only 1K watts and melts the solid easily. Those are so sweet, they also have that red band that grips wire to further aid form being pulled apart. Those bands and heat shrink wraps make them water tight.
