You should also invest in a spindle locknut socket. If you don't you'll be in the crowd with @Grayscale's previous owner, using a scredriver, or more likely a chisel and hammer, to install and remove them. This is something you can buy on amazon, if you absolutely have to, because the torque on those nuts isn't that great and you really do need one.
What I haven't seen posted is wheel bearing grease, for the bearings. The knuckle gets black, or dark grey, moly grease, the bearings do not. They need red bearing grease.
Oh, and you should not replace the trunnion bearing shims, unless they are rusted and cannot be used to set the gap properly across the seat. If you do replace them, you must use the same thickness shims as you removed. The thickness is etched on the shim. IfNo, you cannot read the shim thickness and have to replace them, you also have to get your hands on a setting tool. The procedure for using it is in the service manual.
I sympathize with your Haynes manual use; I used one 35 years ago, before I found out that Toyota sold manuals. I haven't used one since. Spend five minutes and get a Toyota FJ40 service manual for your year model.
