Pretty quiet in here... what are you working on? (5 Viewers)
Pretty bored waiting on parts for the 40. My brother donated this 80's vintage Kawasaki Bayou 185 to my yard several years ago in non-running condition. Decided yesterday to drag it up to the garage and see if I can get it running. Looks like it wasn't much of a popular model so parts are hard to find. Right now trying to get the rear drum unseized. Motor turns over but carb looks pretty cruddy. For some reason Kawasaki decided to put an electric fuel pump in this thing so that will be my first test.
Fuel pump is there because the fuel tank resides mostly below the carburetor by the rear wheel there. It's a low pressure pump, like 5 PSI. It should cycle until it feels resistance against the carburetor float needle. Pitter patter pitter patter pitter patter pitter patter stop
This one's actually a 4 wheeler. After working through the spark side electronics with Ed via text and confirming the fuel pump worked i pulled the carb and cleaned it with brake cleaner as best I could and let it dry out. I've never done any carb work so didn't want to go to do irrepairable damage. I cleaned the crud out of the bowl and removed the main jet and cleaned that as best I could. After getting it all back together I couldn't get the started to fire off using the switch so I jumped the solenoid. About 4 cycles on the starter with some starting fluid and she coughed coughed coughed and ran. I had to fiddle with the idle screw a bunch to get it to idle off choke but I got it. Reveling in that success I decided to step through the wiring diagram I paid $15 for online and figured out there's some kind of neutral safety switch that goes to a relay to close the circuit to allow the starter switch to function. I can't figure out how to confirm its in neutral since the shifter allows me to keep pushing down on it. There's also a reverse on this below neutral so I might actually be there instead. The way the diagram shows it the neutral switch goes through a light bulb socket on the dash that's completely rusted. I ended up making a jumper to bypass the neutral safety relay and was able to use the start switch on the handle bar. I felt pretty good about myself until I then couldn't get it to fire back up after all that. I was losing daylight so gave it up at that point. I didn't get my delivery of parts today so it looks like I'll be working on this again tomorrow if the weather's this nice again. I need to read the manual and see how they say to adjust the carb maybe. And I might try to figure out that safety switch.
I’ve started one of many projects. Here is a clue to one project I’ve started
I pulled out the Holy Grail from my 82 FJ40.
H55f and 38mm split case... someone missed out on this!
I was so used to riding dirt bikes, that when I got on the 3 wheeler I would run over my foot constantly. Fortunately it had worn out tires so it didn't suck my foot under.
But they are f-ing dangerous, especially in down hill turns and off camber terrain, or just a guaranteed eventual trip to the emergency room.
When I was 15 I nearly decapitated myself on one while blasting through an apple orchard. Just nicked my scalp with a branch at about 40mph... never rode one again!
My translation app says : When I was already an adult I almost became a man when I tried to run MT’s (Man Tires) on my FJC. Just barely managed to prevent my wife from taking control of my sphere sack...I’ll never ride them again!
You’re ridiculous...
Yeah, the parking brake set up is still in the box, waiting to be installed. :) I need this top plate for the application that it is going in so it works out. I guess I will just have to take the Silver edition, not the Gold one! The v-8 swap moves everything forward 3" and the 60 series top plate is 3" back.
Swapped out the rear diff cover and started working on swapping the front hub until realizing the new one wasn't the right part... had some old man constantly yelling at me and telling me to hurry up. Even tried killing me with a grinder while I was working on the diff cover...
Appreciate you letting me work on that in your driveway old man! @76FJ40
That sure was a smooth shifting H55. Glad I had a chance to drive the 40 before you removed it!!!!!
Still shift great with the 60 series H42!
@JohnVee
Thanks @OTRAMM
“Man tires” accomplished...
*skinnies were on back order so had to go full monty... 285/70r17
