Getting ready for Moab
mwalls54
Cruiser Nutjob
Roanoke, VA
Getting ready for Moab Build
I started a couple of projects in order to get the rig ready for Moab. 1st is front bumper with warn 9500ti winch. I had no idea what design I wanted to build but I had to build it around the big winch. So I just started cutting metal and welding. Here are some pics of it almost finished for now. Later I plan on putting some 1 1/4" tubing on it but this will work for now.
2nd is sliders. I already have the metal cut and ready just have to weld them up.
3rd is rear bumper with tire carier. Havn't started on it yet.
During this I am going to get the carb rebuilt and do a desmog.
Here are some pictures of the bumper.
More pics
Last one for now, I am putting some 1/2x2 1/2 flat bar in the holes in the front with some clevis hooks for tow hooks.
Headlight washers will be put back in and functional
Great Looking Bumper!
Don't forget to put aside for little things too...for some reason Cruisers tend to show their ass right before a big rally.
My Current MOAB to-do list:
Top Radiator Hose & better clamps
Thermostat bypass hose clamps
Belts (Green Stripe)
Valve Cover Gasket
Lifter Inspection Panel Gasket
Double Check Oil Galley Plug
Pan Gasket
Cap/Rotor/Plugs
Oil Filter
Fuel Filter
Intake/Exhaust Gasket
EGR downpipe Gasket
Silicone Vacuum Lines
Dizzy Side VCV
Rotella Oil
Grease All Zirks
Rear Spring Hangers and Poly Bushings
Rear Internal E-Brake Cam Cables
Adjust Rear Brakes
Check Front (Helicoiled) Caliper mount bolts
Mount Air tank/Fill Airtank
Mount Fire Extinguisher
First Aid Kit
Check CB
K&N Air Filter
Rear Hitch Cleavis
Snatch Block
Tire Inflation Gauge
New Rear shocks
Gear Oil for Diffs and TC
Steering Stabilizer
Check all recovery equip.
Good Thing its 3 months away
yeah I have to do the routine stuff still yet. I am planning on doing long fields and a front aussie too. Maybe a H55 if its in the budget.
Matt-
It's a good thing your getting that bumper done before Moab... the way B wheels he may need it.....LMAO...
BTW-It looks great!
Now i know why he hates mud lol.
keep the pics coming- looks great i want to see the sliders...
Matt-
BTW-It looks great!
There's one in every crowd..... SOB's.... :flipoff2:
bumper is almost done. I just have to ground down some welds and maybe do some tubes for the bull bar. Havn't decided on that yet. but I moved on to the sliders. I am going to add 1 1/2" tubes and expanded metal to finish them for some steps.
what size are the main slider tubes?
i hate to be "that guy" but do you think i could trouble you for a picture of that bumper from the back (the truck side)? also whats the measurement of the vertical plate in front of the winch, and the overall height including the sloped part? thanks!
The front strait and slanted pieces are 6" wide. I will have to measure it to see the overal height. and i will get some more pictures tonite of the back side.
thanks! youve actually been a great help to my design process with this build:beer:
overal height from the top to the bottom is 11" I will have to load the pictures tomorrow.
the bumper is looking great!!
Are you going to give it a coat of paint from the old rattle can or are you going to have someone powder coat it for you?
I am just going to rattle can it for now. I havn't decided if i am going to put some tubing on it or just leave it like it is. I have been thinking about lineX on it when its done.
