Preserving Patina - How To Tips and Tricks (4 Viewers)
I haven't tried this myself, but the old timers used to tell me that wintergreen oil was used to soften up old rubber.
Thanks
I will research that some pending other options others have tried.
Old faded ass 60 getting some love.
Very nice specimen to start with and you really did bring out the best in that paint!
Looking for advice. My 60 has a cheap re-spray over the original brown paint. This thread has inspired me to bring it back, rather than re-paint the truck. I attempted Goof Off with 00 steel wool. It takes off the respray, but is also taking off some of the base coat. What do you think? Too much pressure? 00 is too coarse? Try a different product? CLR with steel wool wouldn't touch the paint. Thanks for your help.
Before:
After:
I have a set of head light guards like the ones pictured on the 40 above. Only other set I have seen. I had thought they were someone’s home built deals.
Another rubber rejuvenate--try dot 5 brake fluid--it's pretty much pure silicon--read the label to make sure it doesn't have the petroleum based ingredients that something like Armour-all has--bad stuff--do a test patch first(you can also mix w/glycerin)--if you can find an old copier in the trash, they usu have a half full bottle of this same mix--mostly silicon oil--really refined--keeps the rubber protected and supple--
Question on preserving the front floor board of my truck. Have been cleaning a ton of old carpet residue off, then planning to put the old stock mat back in place. Much of the paint is in great shape, but the drivers side has a fair amount of paint loss - though no rust issues. Prior to putting the mat back in place would you treat with rust converter then fluid film, or just fluid film (or go some other route)? Thanks!
