PabloCruise
- Thread starter
- #441
I need those wire connectors in my life!
I need the weather to warm up so I can fix the rest of my harness! Forecast calls for a high of 8* F tomorrow...
The problem with the sticky vent lever is more than likely binding in the cable itself. You may have to remove it and try dripping some ATF down the wire to free it up. PITA but ajob
That's part the lock system. If you don't want somebody to open your tailgate with the handle and the glass, you need that working. The window has to be lowered in order for the handle to release from the sides. If you don't need that safety feature, just wire that bracket that your finger is on, down. if you leave it loose it could jam up the window. Hope that made some sense.
Then I thought I would install the kick panels I got with my door panels.
At the same time I cut up the roof pipe pieces posted elsewhere to install some 4" speakers up front. I cut up the passenger side and all was well. It wasn't until I did a lot of cutting on the driver side that I realized I would interfere with the hood release! Argh! At that point I was out of patience and moved on. I can go back with the cut-off on the Dremel and clearance for the hood release.
View attachment 1103378 View attachment 1103379 View attachment 1103380 View attachment 1103381
Nice and clean![]()
