- Thread starter
- #81
As I alluded too a bit, the idea of an under-the-vehicle (sort of in the area vacated by the spare wheel) air tank is an attractive idea. Anyone done something like that, rather than have a tank inside the body or engine bay?
How big is your tank? I will give you the blowing out the air filter, however our filters are meant to be washed out. The rest, I'm not sure. With these small tank setups I'm seeing they would be hard pressed to run a finish nail gun.1. An airtank saves time ... while changing from tire to tire the compressor fills the tank, the pressure-difference fills the next tire much faster.
2. Way better chances to refill a tire, that has slipped from the bead due to very low pressures, without using those materialmurdering and dangerous tricks with brakecleaner and fire
3. The possibility to use the pressurized air to blow out eg. your air filter
In desert driving conditions i see a clear advantage ... my 80 is used as medical for a german rallye in the sahara desert ... the possibility to quickly adapt the pressure to terrain conditions (desert dunes, washboard piste, tar the last miles to the hospital) is crucial.
My $5 option has held up for many yearsWhere did you get the bracket for the windshield washer . Installing dual battery setup and need to find a home for it. 97 Lexus
forum.ih8mud.com
I've got the pacbrake version of that air compressor, its pretty good! With the truck on airbags I have to drop it everytime I squeeze the truck in the garage and air ti up everytime I pull it out, it gets a lot of use!
Have only seen one answer to this. Anyone else care to weigh in on the PRO side of tanking it vs 100% duty-cycle twin compressor (and no tank)? Is there still a point to running a tank?What is everyone seeing as a benefit of having an air tank?
The answer to this question is just look at the one sitting in your garage! Why does it have a storage tank?Have only seen one answer to this. Anyone else care to weigh in on the PRO side of tanking it vs 100% duty-cycle twin compressor (and no tank)? Is there still a point to running a tank?
Alas, my garage is compressorless. A big garage tank will fill multiple tires, run tools for a good while. These aren't big tanks. For example, I know a guy who runs compressor-only (100psi, 100% duty cycle) b/c his 2 cubic-foot tank is empty before it fills one tire, so he figures what's the point of hauling a tank around. What do you use your three for, and how big are they?The answer to this question is just look at the one sitting in your garage! Why does it have a storage tank?
My York has 100% duty cycle, and yet I have three onboard tanks. For those of you with an electrical air compressor, having an air tank will only help the compressor run less, and hopefully get less hot.
Running a tank will not hurt anything, it can only help to extend the life of your air compressor.
That space is reserved for a supercharger.
And if you were using electric tools--would you still want a tank?Air tanks are like batteries. Both are there to add some storage capacity for short duration high demand. For long duration it comes down to the alternator or compressor.
My shop compressor is an 80 gallon 2 stage 7hp speed air that delivers 24.5 cfms at 150 psi. When I’m using my blast cabinet continuously the compressor doesn’t cycle. A larger tank would only delay when the compressor would kick on and then it would continuously run.
Provided the tank is big enough it would help if using air impact tools in short bursts. Just like a second battery helps with winching.
Most have moved away from air tools and gone to cordless. In my garage I’m airing up tires, painting or blasting. Since painting and blasting on the trails is very rare I just want to air up tires. And I’m not putting a lot of time, effort and money into saving 5 minutes on the last day of a trail run.And if you were using electric tools--would you still want a tank?
