WarDamnEagle
Those are quite large.
No blinker on these, no wires in the mirrors.mine came with the same chrome mirrors, but i thought they were too big so i got the smaller version in black, then realized they were too small so i got the taller OE mirrors in black and have been quite happy, they are convex slightly, you know "objects in mirror" but i still put a blind spot dot in the corner.
your new mirrors are like the Clear View also,,,, waay too big for me but we all have our own thats what makes these builds fun to keep up with.
looks like they have a blinker function? you gonna hook that up?
Did you use a pneumatic or battery-powered caulk gun? I'm debating on buying one if I go this route, and esp. if I get the Alu-Innovations top. Did you use an entire tube per window?Installed Xploreglazing sliders on all 4 windows.
Not in love with drilling holes to mount these, nor the amount of caulk needed around them after install. I'm not great at running a bead of caulk, so it looks good from far, but far from good.
Painted the recessed part of the window with master series silver first.
I used just a manual powered one. I'd recommend you make a relatively small hole in the caulk you're going to use. Xplore sent me a tube, but it was DOW791, but just a singular tube which I knew wasn't going to be enough. I ended up using a GE black window sealant. Took one tube for each side, so two tubes total. GE Advanced Black Silicone 2 Window and Door Caulk Sealant 10.1 oz - Ace Hardware - https://www.acehardware.com/departments/paint-and-supplies/caulk-and-sealants/caulk/12545Did you use a pneumatic or battery-powered caulk gun? I'm debating on buying one if I go this route, and esp. if I get the Alu-Innovations top. Did you use an entire tube per window?
So, have had transmission or clutch issues the entire time I've had this truck.
Now, if I give the gas pedal any semblance of force, the vehicle redlines and I get a burning clutch smell.
Clutch is shot yes?
Vehicle still driveable in 1/2/3 gear, just zero ability to "floor it".
Thanks Juan. Haven't checked the accelerator cable but will definitely check.Hello,
Have you replaced the accelerator cable?
In old age, metal fatigue deforms the cable. It cannot control the carburetor properly. You either get too much rpm or not enough rpm.
And yes, maybe it is time to replace the clutch.
Juan
Finally got my 200 series back, taking the troopy in for servicing next week.
There is certainly some slack in my accelerator cable going to my carb. Is this too much?Hello,
Take the chance to install the two cable supports that bolt into the engine block. One on the left-hand side, which is used on the 1FZ-FE. The other on the right-hand side, which is used on both the 1FZ-FE and the 1HZ.
Juan
Thanks Juan!Hello,
It does look fatigued.
It is better to replace it.
Juan
Hello,Thanks Juan!
I will start looking for this part!
This looks like the right part:
Dropped her off at Cruiser Tech in Laguna Hills, California. Mech who drove it confirmed my clutch is destroyed.
Getting the clutch fixed, along with the tranny (H150F) rebuilt.
They told me they'll be getting in touch with @cruiseroutfit for parts!
Thanks!Jealous of your jerry can carrier on your Kaymar. I have twin spare carriers, wish I had a can carrier. Thinking of a way to fab one up using the left spare tire carrier.
Good luck with your trans rebuild!
Thanks!
I think you can change the swing outs if you don't have a Jerry can holder. However, LRA isn't a Kaymar dealer anymore, meaning you cannot order through a US company.
You'll have to contact Kaymar direct in Australia and get it shipped. But shipping is outrageous because of how heavy it is.
