Build Oman -> SoCal 1995 FZJ75 Troopy
i run an Eaton, i have the breaker and fuse near the battery and ran the wiring along the frame and sistered to the brake line.
there is also a mud member here that 3d prints an adaptor for that switch to snap in the large square dash plug.
the whole assembly works great.
Thanks for the details! Glad to hear you like the Eaton.
I was just gonna use the OEM plug vice anything 3d printed.
Upgraded the torn/worn OEM speakers with a new set of 4" speakers. They sound very good in the troopy.
Reused the OEM cabling and mounting system.
OEM plug is not the same size as our 70 series, just a hair small, hence the printed adaptor.
Good to know! Got a link to this 3d printed part?
i dont and i am trying to remember his mud handle,,,, i'm sure someone will chime in.
Is this what you were talking about?
He's (@ChaserFJ60) doing exams just now, so shipping may be delayed until after 20 May. He has some other really cool offerings for 70 series, check it out.
This is exactly what I’ve been looking for!
I don't know the PN, seen it recently but don't remember where, but there is an OEM switch that only has RR for diff lock too. I'm pretty sure @ChaserFJ60 could modify the file to match that, with one detent for only the rear locker.
Haha, saw it in this very thread
Ordered an Eaton E-locker today, part# 14212-1. I'm looking to integrate this into my dash on my troopy using the OEM switch. Since I'm only planning to get a rear locker I'm ordering part number #84725-60030 (photo #1).
Does anyone know the plug part number that goes into the back of this knob? Also the electrical wire leads that will fit into it?
Thanks guys! Will definitely order that. I'd have been pissed!
Anyone know which switches fit under the HVAC controls?
Also any panels that will cover up the space for the clock and the space for the ashtray?
I'm pretty sure the 70 series switch sizes are specific to 70, there is another mud member making cool custom rockers and switches for 80 series, but alas, no fit.
I don't know of anyone doing a solution for the 70 series clock, but there is a mud member making a mini switch/gugae panel for the ashtray space. But again, I don't remember who, I'm just not good about bookmarking this stuff.
I'm not totally convinced that this is true, but says it fits 70 series:
I would think what ever switches you want are still available... In those slots from left to right I have a blank filler, rear wiper, rear defrost, and rear fog light. What switches are you after?
At some point I thought I found a PN for a blank cover for the clock. Memory is foggy on if I tried to order one and in was NLA or if I never got around to ordering it at all. I'll check some notes and see if I can locate the PN I found.
These look like they may fit, thank you!
And I have no idea what I want to switch down there, just that I may want to switch... Something!
Some more switch intel that may be useful:
Since I'm not a rocket surgeon, dropped her off for the Eaton E locker install. They're only doing the install, wiring is on me!
I'm also looking to have my carb tuned/rebuilt, and figured I should get it done before I move up to the high desert in 29 Palms. My truck smells like a lawnmower after I drive anywhere, I assume it's because the carb is in a need of rebuild, etc.
Is there a recommended carb rebuild "kit" or something like that I can take to my carb rebuilder or just drop that sucker off?
