Official 37" and up picture thread (15 Viewers)
Rather than tire brand debate I'll stay on the topic of 37's and fitting them. This is my front suspension compressed to within about 1.5" of full stuff with a 37x13.50 Toyo MT. Front axle is moved forward 1.25" I had to trim my front bumper a bit and some of the inside of the flare but the wheel itself is pretty centered in the wheel arch.
Untitled by Adam Tolman, on Flickr
This is the rear at the same spot and within about 1" of full stuff. Rear control arms are extended Blackhawk arms. You can see at full stuff how the extended arms put the wheel farther back in the wheel arch. I had some rubbing at the rear portion of the wheel arch that meant removing the stock mud flaps, trimming a bit of my rear bumper wing and the inside edge of the flare, and rolling the lip of the fender sheetmetal. There is still light rubbing but everything that touches is now pretty smooth and doesn't damage anything.
When I go with 37s your setup is how I want to go.
I think not
But if that was the case they would be a very well rounded tire as California is one of the most diversified states.
you could be surfing in the morning rock crawling midday, and then snow wheeling in the evening.
Boy did this thread get derailed let’s try to get it back on track ladies
Hehehehe
I cut out the wheel wells in the front and the lips out of the rear. The lips on the flares were cut out because I’m running a 17x9 -38 wheel. 17x9 -25s seem to slip by the lips on the rear of the flares by just a tiny bit. The front and rear had the equivalent to a 1.5”ish bump stop extensions. The rear rubbed a little but it never really bothered me. The front has about 5” of uptravel and the rear had about 7 with a 3” lift.
So pro comp is no longer making their steel wheels and one of my 97s is bashed beyond repair.
Any recs for a replacement? It should be cheap because I'm going to beat on it.
The 97 is 17x9 with 4.25" backspace and 19mm offset for reference.
I would argue that you should get something nice because you're going to beat on it. There's a reason you need to replace one
Instead of facing this same issue again why not pull the trigger on some good, not cheap, beadlock rims?
Beadlocks not exactly road legal. And I don't want to spend more on rims than the truck is worth
Then run a add in the proper place !
The classified section 🤪
I just bought a set of four about a month ago.
Cheers
39s are the new 37... just sayin.;)
Zero bananas givin here.:banana:
Flare or No flare.
How much lift do I need to fit 39s?
AP1GczM583Cs-hVdI9CL8mId0Bc190qr_BlHciECLzoEWPn4-QuDDlUtBMs9lzf5XgIDF_Au7GK3a4GhIRUPMZMdMt3rdE91_0eCJb-ukQ70MmokQgDrO7-Ab5DyYNuELW-B-R5zMweXKA1tngOIFD-dxIpryuNzBIe5KMc9e-muHBG0Ub9BLXdZ8T6NIy8JKCWu8q8MdjkNtbpvjOev90NPbMli0UsC1COH3v-Lg6_Vl9LeWW0r8w1yU2JYmmnKZaARKB7rtErEH0Ufwm53Le0IKlhJBEJVEAwdxECrvUPNDe96kNqU3sUqF4Zx3SbGpOZkdr5_COzVw7G_BZG88dN4H5ad21X9VbJBZcLNOpcVAsMIdnV0qDlCNosNhTy42fxpFDfk5gHa4WIHutJpMxsnLhhOFCjSI0jznjXic2waTDps_wdA0xOPBcF8zB2sByb2ekN9IEQvSn15CtO5QXmvPUz8ca-6MhuuNRGwCDvLuYr7ttS0jcLfegubFm4VpUeRelGycfBTRhBRFlnYumOxbtfZUCeZQ8fbm_6cjiMd6Gu-ICAKOZKu_xLU8KxFhDfvM0C2mt0jtz5f72LFoNAqERl2xHt397e9mHQmLOhsfyjw6lDFKz0LOakoXnwsjYGXg0XoF3FobLsqvmZchIk92uMX99g3JSuMIVCDIK0UZa-MEjIvNpC4LCX8S39MlPFihLmD8oQgug_ZIOmvRE2SThJQf2mC5pWQbpf9J0rm--Nl3uIoSO0U42tAD8Xt8LkZJ3LuTW0cmaQ2IyQJEl1isArcjLJVxzfS1wr5Is4YJDWGNcVTj6l9Sf1sK1lg8oU_oOMce5wpI_xt_A9Vro14ctOzRG7J4WOtiosPCBSR75DMCgxCvSdZWRRqfv9Kp_e6ploX6nZD17zHuDanr7uVoVXw=w1546-h870-s-no
AP1GczPPjq5v8iy-7sQjnNkWB7l0RjRvaQV72vBJzbfY19DN7FRK2SBMHmenrkjYlN7e5ginpGl6557zOBUBMn26-V4XGceU6-RsFt-OjWTI9kf-VfHV_NdWT7XW16yX9NvM50xod5X4ihyIsamkpg4kQYKEVShxaGcqa7iNsFDEL9jTHxjLcO9fLtffuqhOXtX7r0_dxRuI6fcz6cde4elYDSKtei6eDUZMPJdMPygCxCoFR2tL3TmDhuUGolkRNB_hG97qGGPochQRhDUI28YbPUOiKClVZYWozSIdveZ7ndFwfLKScuzN-nBaYm6Pzck1jrpfiZgoujuyJKtlnFErkHVnICGOifHKEAs8v_EIRySFsbCPyHk4s2L-uHC_mcwvrgrYEupb-VVqaAw-aPcsJRrhyj0mFPUa6HpBxaMVZe6Oj8k7U76hMF8De-p5hCfuSjmtbjKt9CfXuxwEpF0ifliWqEMsTAdwGL60jly3v2hz7wi3GsmweBg5lkM6S4W_zKTRsSgQ_omkmib87FZHtz5DHp40Yjcb6XTnPZHzjXVenx37L8247TZL-GeLCsvf96Bo5gNvXUu0fLan-1buQEb7GjaqalqHT8H-1ZYIKzcyINUE4xRDYDZgLjVeCfYgggTY1CVPYoftr-9FWXbTDsBSAe2HJg7SS1C7ywu-gU9Nedx1oOkYYdaXzRBZT4ZKeyk5TcYwoKcEn01KQYVBnllcHzICPqbQ6lE1WlWRkcKy75wEE_c0odx7Qgng0WJq5qH9Mq2W6oC6WI_zUKUZ58Gk5FLQdubdbwjfUZ4vhGeZ0AJJZaWC3UCKWY57-d6FxFlTJmhiPL4wUKWRG9oq_1l6T20_YGHh0KEVqoC0asmWXXfry5yysixpncKLFLOjnBNkufAO-E9afx47CtyhL0VZkw=w1301-h870-s-no
Added 37s over the weekend.
Lift: OME Medium 2851/2860 with 30mm front poly coil spacer
Tires: Falken Wildpeak A/T4W 37”x12.5”R17
Wheels: 5th Gen 4Runner Steelies in 17” x 7.5” with 4.84” Backspacing (Toyota PN: 42611-35430)
I’m getting some popping from the front sway bar, so I’ll probably add some 1.25” swaybar spacers. And lower front bumpstops. Lift added 3.0” to the front and 3.25” to the rear.
DVS rear panhard bracket and caster arms ASAP.
Just got some 37" Mickey Thompson Baja Boss MT's installed on some Icon 17" wheels. I really need to install my 4.88's now. lmao.
Already getting some rubbing on the front tires, rear part of the wheel well. Maybe need to do the Delta long arms?
