Sunroof and Headliner removed pictures
Down in Loveland, have you ever looked into this shop? When it gets right out I’m gonna take my 43 down there to check them out.
Ctr4repair.com
Yes, I went to them first. They sprayed it down with water but couldn't reproduce the leak. They suggested I replace the windshield and gasket. I did do that but with NocoTint. Looking back on it, I felt more confident with Empire but they priced themselves out compared to NocoTint. Who knows what the outcome would be if I went to Empire first.
On top of all the above: remove the kick panel/sill plates on both sides (dead pedal needs to be removed also). Then flood the windshield one section at a time (bottom left, bottom right, center, top left, top right, center) for as along as it takes (ie: an hour if needed, or wait for a big rainstorm) while the sunroof is sealed with tape as mentioned. Then take a bright flashlight and get up under the dash best you can, search for drops of water hanging off the wiring and brackets. While the carpet is loose (sill plates removed) check the floor gutters for water, remove a hole plug to let it out if you find any.
