New to FJ40 Scene
Foam for Seats?
We thought the foam for the seats was going to be OK and usable, based on how they felt. But, once he got the covers off the seat foam was full of surprises, like mice nests and mold. Yuck!
Does anyone have a good recommendation on where to get replacement foam? I know SOR has them, but if someone knows of another source that is not as expensive please let me know.
Thank you!
You might checkout this thread and video.
If it was cheap to ship…but it ain’t….. we bought an acid reflux assistant known as a BEDGE…. It is a wedge shaped hunk of foam in two pieces 80” long but wedge shaped from 1” to 8”. If you glued the wedges in opposite position you have a 9” thick rectangle 6 1/2’ long and over 3’ wide. That where the electric carving knife is valuable and you could carve what you wanted. Check around for foam…there is a flea market guy here that sells blocks of foam rubber and his go to trim tool is the electric carving knife.
As for the acid reflux aide? It’s like sleeping on a cliff and waking up in the middle of the night sliding 1/2 way down the mattress. It’s sitting in the shed taking up space
I've seen guys on car shows like Texas Metal, Bitchin' Rides, and Iron Resurrection using an electric knife to carve and shape foam for upholstery. And I thought about that, but my tremors make me question my ability to do it (and the more active I am, the worse the tremors get). My wife redid our dining table chairs, so I tried to talk her into it and she said "HECK NO!" LOL!
So, I sucked it up and ordered all new foam. 😞
Paying extra for registration is a waste of money. QQQQ might be worth it.
A friend had 4Q in high school on his VW bug.
Told the DMV lady he was a football player
A picture is worth a thousand words. 10 pictures would be worth 10 thousand words. Catching my drift?
Engine Update New
The engine fired up yesterday! And with the new coil packs, new spark plug wires, and the exhaust headers ceramic coated & baked, I think it looks better! And I remember 30 years ago I bought a pair of Sanderson Jet Hot aluminized ceramic headers for the big block going into my 1934 Coupe, and they guaranteed it would reduce the heat in my engine compartment 20 degrees and increase the horsepower. So, hopefully these being ceramic coated will help reduce the heat in the engine compartment. I thought about putting coil covers on to look like valve covers and putting "TOYOTA" down them, but it looks nice now so I hate to cover the coils & wires.
After all of the energies invested in your re-build I really hope you love the heck out of it and enjoy it everywhere you go
Me too!!!! Instead of the "cheap, get it running as is and drive it" project that I intended, now it is literally going to be a brand new FJ40. Every bolt & nut (stainless steel), every gasket, seal, rubber piece, window felts, body mounts, everything is new and/improved (like all of the light bulbs big & small being replaced with LED so they will last forever). And with the epoxy coating / sealing it should literally last forever without rusting out again. So in a way, it should be better than new. And only cost probably 10 times what it did new!!! LOL! Probably more than that! 🤣 :rofl:
FYI, this was tried without the O2 sensors installed, but everything I've read says the O2's don't factor in until the engine has run for a few minutes and is warmed up. If will fire for a couple of seconds, then nada. Any suggestions appreciated. See video below:
lS swap crank attempt
Could just be the video but not hearing the fuel pump after it fires and fails. The corvette regulator is plumbed the opposite of logic as well.
I don’t see exhaust, radiator hoses, battery mounted.. personally I do not really see the point in a fire up until it is about ready to drive. what is all the clicking in the video?
Junkyard Marketplace motor. To verify it isn’t junk. His “warranty” expires soon. So if something major was up he could exchange it before he gets more installed and around it. Key cycles on the ignition is the sound. New Toyota one so it’s cycled all the way off then back on.
Vats is showing disabled. (Had a friend plug into it to read the program). Still acts exactly like a vats issue. Since this video it will fire every time and die within 3 seconds. ECM is not losing power as the live data is not dropping out and the pump is controlled by the ecm. Stock 5.3 pump 58-80 PSI. Tried a new regulator as it was probably due and worth the shot.
Live data won’t read the TPS at all. Even with two tried. Movement/holding the throttle in different spots doesn’t change anything. It reads - coolant temp. The harnessis an Amazon/ebay cheapy sold as a custom harness build by the engine seller. The tune is the engine seller. I believe the harness is the problem. Would need to be pinned out and traced like by line. But more LS experience is in this thread. Just in case someone has experienced the issue before with an Amazon harness Don asked the group.
Sounds like another round of tuition. :/
