- Joined
- Apr 14, 2004
- Threads
- 1,469
- Messages
- 36,718
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
How to get the broken bolts out:
Broken Thermostat Housing Bolt. Now What?
Hint: There is no better way!
surprised nobody has said to use anti-seize when threading the 2 halves back together.
I always use anti-seize when assembling anything. Even body bolts.
Loloh man I'm not touching my thermostat housing.... Ancient thermostat and housing ain't broke yet but I can pretty much guarantee if I play around with it it WILL be broke.
I think this would be a great discussion. Maybe a new thread?I have a unique Question for everybody to Input on :
Is loch-tite , specifically Blue Serviceable type considered or has a side benefit of being Anti-Sieze as well / Also if used Liberally ?
While Heating Up the Broken stud / Bolt is the idea , then rotating it a bit back and forth to loosen up the Scale , Borate &
Ethylene Glycol related corrosion , Take care NOT to heat up the cast iron cylinder head as little as possible . Just focus any Heat
on the broken bolt / remaining stud itself
Matt, I broke a Tap in one of the Thermostat housing bolt holes. I’m in a pickle. I was going to try to drill it out with a diamond drill bit. It heating that area a bad idea?
Will there be enough meat in that hole if I have to re-tap to a 12mm?
Thanks!!! Ron
Thanks!!! Ron
