Builds My 1978 Nut and Bolt Frame Off Restoration (1 Viewer)
Everything's been blasted, epoxy primed, sanded, 2k primed, wet sanded with 800 grit, and washed.
Ready for paint now.
img_9087-jpg.1405190
img_9088-jpg.1405191
img_9089-jpg.1405193
img_9090-jpg.1405194
img_9091-jpg.1405195
I think I invented the best way to clean old rubber on these Toyotas.
I used a Mr. Clean magic eraser soaked in acetone.
The results speak for themselves. This was after about 3 minutes of work.
img_9138-jpg.1407527
img_9139-jpg.1407528
Taking a break from buffing....
Installed my newly powdercoated roll bar. Used pretty grade 8 zinc fasteners.
Also installed my new roll bar pads from fj40dash.com
img_9140-jpg.1407547
img_9141-jpg.1407549
img_9142-jpg.1407551
Transmission hump/cover is loosely set in place. I did install a new gasket on the bottom of it. Waiting on new fuel lines and new stainless JIS hardware from OverlandMetric.com before I bolt it down. He was very nice to work with, and I will definitely be buying a full kit when I begin my next restoration.
img_9143-jpg.1407581
Made some gas tank pads out of Oatey PVC shower pan liner. Glued it down with clear RTV.
img_9164-jpg.1408084
Assembled my fuel door hardware, which is freshly cad plated, with new OE bumper from Beno, and stainless steel fasteners.
img_9144-jpg.1408086
Also installed fuel door, gas tank, and fuel sending unit.
img_9165-jpg.1408085
Ran the new fuel lines. The grommet through the floorboard is not available from Toyota anymore, so I modified a new OE heater tube firewall grommet.
img_9173-jpg.1408836
img_9174-jpg.1408837
Reconditioned a few parts. Also installed an inline fuel filter.
img_9182-jpg.1409497
img_9183-jpg.1409498
This filler neck is shot. I've got a new one in order.
img_9184-jpg.1409499
Installed these headlight adjusters from @Racer65's storefront.
img_9185-jpg.1409500
Also blasted, primed, 2k'd, and wet sanded the tire carrier assembly.
img_9187-jpg.1409501
Yes, side marker lights are actually still available from Toyota!
img_9193-jpg.1410608
Installed
img_9194-jpg.1410609
Installed my badges, and reflectors too,
img_9197-jpg.1410611
One of the nicest restos ever!
:clap:
Transmission hump is in with new gasket, both cadmium and stainless hardware from Overland Metric, along with new lower transfer case boot from @Racer65 , and new upper shift boot.
img_9211-jpg.1410913
img_9214-jpg.1410914
New voltage regulator. Installed the cadmium plated heater valve too.
img_9205-jpg.1410916
Installed this fuel line and firewall clips (both in cadmium), along with new stainless JIS hardware from Overland Metric.
img_9206-jpg.1410917
Installed the blower fan assembly.
img_9208-jpg.1410918
Wow very nice, feels really familiar.
I'd be lying if I said I didn't read through your build thread several times for ideas. Beautiful work.
Ain't no shame in that man, I got some of your pics saved for when I get to where you are now. BTW very nice work!
Yup, the radiator cap is available from Toyota.
img_9207-jpg.1410919
img_9210-jpg.1410920
img_9217-jpg.1410921
New JIS bezel screws from Overland Metric along with OE bezel spacers from Beno.
img_9198-jpg.1410922
Lots of pretty cadmium. More stainless hardware from Davework
img_9199-jpg.1410923
SEXY
img_9200-jpg.1410924
Just for shi*'s
img_9201-jpg.1410925
Hood bumpers from CCOT.
img_9202-jpg.1410926
I had a lot of help today too.
img_9219-jpg.1410927
img_9224-jpg.1410928
Lots done today
Installed dual diaphragm brake booster from @Racer65 , along with brake and clutch masters.
img_9239-jpg.1411467
Prodercoated smog fan bracket.
img_9240-jpg.1411468
Installed pedal assembly, steering assembly, and heater.
img_9242-jpg.1411469
Lots of little cadmium parts here and there.
img_9243-jpg.1411470
img_9245-jpg.1411471
Great little helper you got today!!!
She looks close in age to my helper. She isnt allowed in the garage yet its still winter here haha.
