Build My 1978 Nut and Bolt Frame Off Restoration
Everything's been blasted, epoxy primed, sanded, 2k primed, wet sanded with 800 grit, and washed.
Ready for paint now.
img_9087-jpg.1405190
img_9088-jpg.1405191
img_9089-jpg.1405193
img_9090-jpg.1405194
img_9091-jpg.1405195
I think I invented the best way to clean old rubber on these Toyotas.
I used a Mr. Clean magic eraser soaked in acetone.
The results speak for themselves. This was after about 3 minutes of work.
img_9138-jpg.1407527
img_9139-jpg.1407528
Taking a break from buffing....
Installed my newly powdercoated roll bar. Used pretty grade 8 zinc fasteners.
Also installed my new roll bar pads from fj40dash.com
img_9140-jpg.1407547
img_9141-jpg.1407549
img_9142-jpg.1407551
Transmission hump/cover is loosely set in place. I did install a new gasket on the bottom of it. Waiting on new fuel lines and new stainless JIS hardware from OverlandMetric.com before I bolt it down. He was very nice to work with, and I will definitely be buying a full kit when I begin my next restoration.
img_9143-jpg.1407581
Made some gas tank pads out of Oatey PVC shower pan liner. Glued it down with clear RTV.
img_9164-jpg.1408084
Assembled my fuel door hardware, which is freshly cad plated, with new OE bumper from Beno, and stainless steel fasteners.
img_9144-jpg.1408086
Also installed fuel door, gas tank, and fuel sending unit.
img_9165-jpg.1408085
Ran the new fuel lines. The grommet through the floorboard is not available from Toyota anymore, so I modified a new OE heater tube firewall grommet.
img_9173-jpg.1408836
img_9174-jpg.1408837
Reconditioned a few parts. Also installed an inline fuel filter.
img_9182-jpg.1409497
img_9183-jpg.1409498
This filler neck is shot. I've got a new one in order.
img_9184-jpg.1409499
Installed these headlight adjusters from @Racer65's storefront.
img_9185-jpg.1409500
Also blasted, primed, 2k'd, and wet sanded the tire carrier assembly.
img_9187-jpg.1409501
Yes, side marker lights are actually still available from Toyota!
img_9193-jpg.1410608
Installed
img_9194-jpg.1410609
Installed my badges, and reflectors too,
img_9197-jpg.1410611
One of the nicest restos ever!
:clap:
Transmission hump is in with new gasket, both cadmium and stainless hardware from Overland Metric, along with new lower transfer case boot from @Racer65 , and new upper shift boot.
img_9211-jpg.1410913
img_9214-jpg.1410914
New voltage regulator. Installed the cadmium plated heater valve too.
img_9205-jpg.1410916
Installed this fuel line and firewall clips (both in cadmium), along with new stainless JIS hardware from Overland Metric.
img_9206-jpg.1410917
Installed the blower fan assembly.
img_9208-jpg.1410918
Wow very nice, feels really familiar.
I'd be lying if I said I didn't read through your build thread several times for ideas. Beautiful work.
Thanks for the props, @gator25
Yup, the radiator cap is available from Toyota.
img_9207-jpg.1410919
img_9210-jpg.1410920
img_9217-jpg.1410921
New JIS bezel screws from Overland Metric along with OE bezel spacers from Beno.
img_9198-jpg.1410922
Lots of pretty cadmium. More stainless hardware from Davework
img_9199-jpg.1410923
SEXY
img_9200-jpg.1410924
Just for shi*'s
img_9201-jpg.1410925
Hood bumpers from CCOT.
img_9202-jpg.1410926
I had a lot of help today too.
img_9219-jpg.1410927
img_9224-jpg.1410928
Lots done today
Installed dual diaphragm brake booster from @Racer65 , along with brake and clutch masters.
img_9239-jpg.1411467
Prodercoated smog fan bracket.
img_9240-jpg.1411468
Installed pedal assembly, steering assembly, and heater.
img_9242-jpg.1411469
Lots of little cadmium parts here and there.
img_9243-jpg.1411470
img_9245-jpg.1411471
Great little helper you got today!!!
She looks close in age to my helper. She isnt allowed in the garage yet its still winter here haha.
