Build My 1978 Nut and Bolt Frame Off Restoration
Can someone chime in here a second?
I know it's not OE, but when I start assembling body panels, I'd like to cut some thin pieces of rubber to place in between panels that are sandwiched together (bib, fenders, aprons, hinges, etc.) to keep things from rubbing together and subsequently rubbing off paint, finishes, etc.
The PO had done it on my 1968 I used to own, and I always liked it. Anyone know of a good material to use? I was thinking heavy mil rubber that you'd find in a shower pan liner, but I thought that may be a little too thick.
I just starting reading your thread, so this info maybe too late. This seller at Ebay sells different precut rubber pcs for the various parts of the body. You might check his store. kenootski | eBay
Cool. Thank you for the link
img_9283-jpg.1413077
Installed these cadmium plated clips for the lower dash pad.
img_9286-jpg.1413560
img_9287-jpg.1413561
Loosely fitted the floormat.
img_9290-jpg.1413562
I now have a windshield assembly! New glass and weatherstrip too.
img_9295-jpg.1413849
New grommet and new rear view mirror assembly.
img_9296-jpg.1413850
New upper dash pad. Installed lower dash pads too.
img_9297-jpg.1413851
Installed door strikers.
img_9298-jpg.1413852
Also installed windshield assembly gasket and ran the wiring harness, along with wiper fluid hose. That's a new OE grommet too.
img_9299-jpg.1413853
Lol
Started fitting the hood
img_9301-jpg.1413874
img_9302-jpg.1413875
img_9303-jpg.1413876
img_9304-jpg.1413877
Thank you.
img_9325-jpg.1414638
Finally getting around to doing this.
img_9324-jpg.1414640
Also, made a big pile of parts to blast.
Found these cool labels on the back side of some of the roof parts.
img_9321-jpg.1414642
img_9322-jpg.1414643
img_9328-jpg.1417041
img_9339-jpg.1417042
img_9341-jpg.1417043
img_9342-jpg.1417045
No idea.
I do most of my work between 4:00-6:30a.m. and 9:30 p.m. and after.
I did.
I was several pages back.
Made of PVC pipe and plastic sheeting.
I've been painting small parts in the garage, with the door cracked, and a fan going.
