Build My 1978 Nut and Bolt Frame Off Restoration
Great Pics for reference for other builds and builders..
Nice work!
:cheers:
Finished running the master brake and clutch lines.
img_9246-jpg.1411473
Then loosely installed front fender and apron.
img_9247-jpg.1411474
You may have heard me talking about my redneck lathe. Anyways, here it is: I take a piece, and chuck it up in my 1/2" drill. I then use bastard files, and various grit sandpaper to turn the piece to the desired diameter. Today's project, was turning 3 bronze bushings down to fit inside of the spare tire carrier hinges.
Turned out great.
Ready to go
img_9257-jpg.1412189
Turning
img_9258-jpg.1412190
It fits!
img_9259-jpg.1412191
Done.
img_9260-jpg.1412192
img_9261-jpg.1412193
Got my new rubber filler neck from CCOT, so installed that, the gas tank, and cover. Also installed some door edge moulding.
img_9262-jpg.1412194
img_9263-jpg.1412195
New emblems
img_9264-jpg.1412196
img_9265-jpg.1412197
Also installed passenger's side hood apron, and fender.
img_9267-jpg.1412198
Also installed new turn signal assemblies.
img_9268-jpg.1412199
I'm hoping I can get it driveable in the next 3-4 weeks.
My problem is, is that I still do not have carb linkage. And even once I get my grubby hands on some, I'm still going to have to blast it and send it to plating, which will add considerable time I'm sure.
I'm wearing t-shirts and Chacos here in Mississippi, and have been since the beginning of February.
Never knew there was a FOOD side to the FJ40!!!
But seriously, dude...beautiful build!!!
You are inspiring me to get back on mine once it stops being 20° here!
Love the little bistro table in the middle of things!
Lol.
Yeah, that's what I set the body on inside the paint booth.
img_9270-jpg.1412202
Installed the emergency brake assembly, along with defrost hoses. I did test fit new eBay gas pedal assembly, which will be bead blasted, and plated. I still need to wet sand the dash and polish.
Boom!!
I'm pleased with the way this is turning out.
img_9272-jpg.1412207
Turned out great.
Ready to go
Turning
It fits!
Done.
That's what I call "slick"
On the steering column harness, what is used for that yellow casing viewable here where the column meets the dash? Is it the factory stuff just cleaned up, or a special thing you did?
Yellow 3m vinyl duct tape.
Super 35, I think.
I do small engines in my free time, so there's always plenty around to use.
