While work was being done on the inside of the cab, I figured out where all the right front wires/harness went. Fit right in.
The 76 series was wired up for lockers, so there was a pigtail coming off that right side harness which would go to them....at least we think. This truck had ABS so there is some of that stuff going on in there too. We'll dive deeper in that once we get some of the parts we ordered last week....pick out what we need and what we don't.
Interestingly enough, this part of the harness has a fog light lead too. The 76 had those as well. We'll probably use it to trigger a relay for aux lighting....controlled with the OEM stalk on the wheel. There is a lot on this harness....wiper, alternator, right headlight/turn/city, AC low pressure switch, side marker.....fog light lead, ABS, locker(?) in there too. And the vacuum reservoir warning light(assuming there is a light). I think I saw a lead for maybe an air filter flow detector or something....some VSV stuff too.
Another interesting thing....the side marker/turn signal light was capped off. 76 must not have had side markers.
