HOPE this isn't a first! Fuel tank issue
Discussion in '40- & 55-Series Tech' started by flipout007, Jan 12, 2018.
  1. flipout007
    flipout007
    54
    2
    Sep 27, 2015
    EL Paso Tx
    In the final stages of getting my 71 fj40 running. Took it to fill the tank and the trip back from the gas station revealed a massive leak from the sending unit. No biggie, I'll replace the gasket....well, like most things it wasn't that simple. Seems that sometime in the past the rubber gasket had been replaced with a much thinner paper gasket allowing the retaining screws for the sending unit to bottom out against the tank. This has forced the ring that the sending unit bolts to, to separate from the tank. The ring literally came off with the sending unit. I'm wondering if anyone has had this issue and if so, did you figure a way to reattach it. Looks to me like it was originally soldered in place. Not sure soldering or welding on a ~ 50 year old tank is the way to go.....any ideas?
  2. 1969FJ
    1969FJ
    463
    360
    May 14, 2016
    Arizona
  3. flipout007
    flipout007
    54
    2
    Sep 27, 2015
    EL Paso Tx
    $500 for a new tank and with SOR it'll be another 200 for shipping - there has to be a cheaper alternative.
    rkymtnflyfisher likes this.
  4. B y r o n
    B y r o n
    882
    Media:
    9
    Albums:
    2
    303
    Dec 13, 2012
    KY
    They make epoxy that will work in a fuel environment. Maybe you can simply glue it back in place.
  5. 76 FJ40
    76 FJ40
    3,339
    2,895
    Aug 1, 2012
    Huntsville Al
    You can still buy that tank new from Toyota. That's where SOR, CCOT and others are buying them from and marking them up.
    rkymtnflyfisher and mrboatman like this.
  6. Splangy
    Splangy SILVER Star
    6,536
    955
    Aug 4, 2009
    New Hampshire
    You can probably weld it back on. Drain the fuel and wash out the tank with soap and water. Make sure you weld it in the correct orientation so the sender hangs in the right spot.
  7. SmokeandNoise
    SmokeandNoise SILVER Star
    7
    4
    Sep 6, 2017
    Rockwall, TX
    If you decide to go for new, try Camelback Toyota. Their online prices might be a little higher than others, but they don't charge extra for FedEx ground shipping.
    Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
    I've used them for brake and steering parts and they've been good to deal with.
  8. middlecalf
    middlecalf SILVER Star
    926
    354
    Jul 20, 2004
    Sweet, Idaho
    Unless I don't understand something on their website they only go back to 1980. This is for a 1971 rig. I have come across this same issue with every online Toyota parts outfit, none have online sites that list anything for older rigs. Maybe they have to be called. And I've struck out with other Toyota OEM vendors, not a good track record for me. Rant over.
    I'd JB Weld it. But that's the way I deal with things like this. YMMV.
  9. thebigredrocker
    thebigredrocker SILVER Star
    2,460
    2,154
    Nov 6, 2013
    How does your tank look inside? You can take pictures of the tank innards with an iphone. Might be wise to do a thorough inspection before you decide what to do. Judging from the tank’s topside I’d want to know what the PO has done underneath.
  10. spotcruiser
    spotcruiser Geezer SILVER Star
    3,488
    658
    Jan 30, 2003
    Western WA
    Two ways to do it:
    Drill and mount the ring to the tank with flat head screws, nylock nuts, and a gasket. While I was at it, I'd also drill through-holes into the tank for the sender mounting screws and put another gasket between the sender and the mounting ring.
    Or you could clean the tank really really well, inert it with water up to the sender hole, and then weld the ring in place. It's not going to blow up if it's completely filled with water.
  11. 76 FJ40
    76 FJ40
    3,339
    2,895
    Aug 1, 2012
    Huntsville Al
    Here's a picture of the tank I bought from my local dealer in March of last year.
  12. 1969FJ
    1969FJ
    463
    360
    May 14, 2016
    Arizona
    What was the cost ?
  13. SmokeandNoise
    7
    4
    Sep 6, 2017
    Rockwall, TX
    Yeah, that's one of the downsides of using the online dealership sites. Most don't cover 'antique vehicles'. ;-D You need to already know your part number. For the savings involved, I don't have a problem with doing my own research up front. The PN for a 1971 radiator is 77001-60013. I enter the part number on the Home page, and the price from Camelback is $340.40 and that includes FedEx ground shipping. Compared to some of the aftermarket choices, that's a pretty good deal.
    middlecalf likes this.
  14. 76 FJ40
    76 FJ40
    3,339
    2,895
    Aug 1, 2012
    Huntsville Al
    @1969FJ the tank was $342.00 plus tax deliver to my local dealership.
  15. 73FJ40
    73FJ40 After another night of rust removal! SILVER Star
    768
    Media:
    4
    Albums:
    1
    496
    Dec 28, 2006
    Western Massachusetts
    @middlecalf
    Smoke and noise meant to write, "The PN for a 1971 radiator FUEL TANK is 77001-60013. Toyota indicates that part number is superceded by 77100-60012. This is for a 6908 - 7109 FJ40.
  16. SmokeandNoise
    7
    4
    Sep 6, 2017
    Rockwall, TX
    Thanks for catching that. I was working on another project and had a brain fart. Sorry for the confusion, 007.
    Dave
