Builds Fly By Night (1 Viewer)
Going with these shackle hangers from Ruff Stuff. Reusing the factory hangers. Greasable pins throughout.
Just read your entire thread from beginning to now. Here’s my plan for the 1969 FJ55 I bought four months ago:
1) get it running well/OK
2) attend the 2020 Pig Party to get shamed and/or inspired into wanting to go deep
3) go crazy and restomod everything I can
You could! Or you could do #1 and then wheel the bejesus out of it for 18 years, show up to Pig Party 2038 and then be shamed🤣
Ha! Not sure I can wait the 18 years at my age! Great work on your build. Very much enjoying and learning from this thread.
A little mid-day update...
Welded up the first and biggest of the frame cracks which were on the inner face of the passenger side. Probably some of you familiar with this procedure, maybe some not so much. Just for the heck I took pics at every stage on how I deal with them.
Since these two spread to the bottom face, I didn’t want my “V” out to cause them to spread, so I tied the bottom and sides together better with a couple stitch welds. Once that was done, I drilled the end of the crack about 3/4 through the material, then“V”ed the crack, ran a root pass, then two more passes on other side of the root. After that, ground it flush in preparation of the fish plates.
Too rigid? Maybe. I think the construction of the 55 frames do allow for ample flex torsionally. My biggest concern with this job is the frame warping due to all the welding. Scrapdaddy plated the front of his frame inside and out and ended up needing the frame tweaked back into square on a frame rack. I’m hoping to avoid that, yet keeping the reality of that possibility in the back of my mind.
