Glad I kept a spare from the several Pigs that contributed to the Frankencruiser. Nice to see the availablility though.
Yeah man, let's resurrect this. I do think we need to know...
Is tapping required? "Rivets for the Pivots" sounds like a dorky band name. @Pighead , please let us know how that material taps if you go that route.
Agreed that the off-center layers make it appear the arc was designed incorrectly. @PabloCruise , I'll revisit our file to assure symmetry, and also check out that gap clearance.
Finally, regarding those layers, that's a natural part of additive manufacturing (AKA 3D Printing). Metal printers tend to print in thicker layers (think topo lines on a map). The coarser/thicker the layer, the more stair-stepping you see in areas of curvature. Thankfully that will buff out. @Pighead , hit that with a buffer and report back!?
Cheers!
Calvin
Why not design the part to use sex bolts instead of rivets for the pivots?Rivets for the Pivots" sounds like a dorky band name
Man, I like those. Where you come with this stuff!Why not design the part the use sex bolts instead of rivets for the pivots?
I don't have a life outside of this stuff.Where you come with this stuff!
See what you did!!! It only takes 1 to set them all offWhy not design the part to use sex bolts instead of rivets for the pivots?
