1970 FJ55
Cheyenne Wyoming
Looking for some advice about body removal on my FJ55 project. Would like to begin prepping to lift tub and front assembly off frame with gantry crane. Dos and don'ts, bracing, order of steps, door removal?, etc.... Any words of wisdom would be greatly appreciated. Thanks
Remove the grill, hood, fenders, doghouse and everything attached to them - radiator, battery, etc.
Disconnect firewall accessories - brakes, clutch, heater, speedo cable, etc.
Remove the doors and tailgate.
Remove the trans hump and shifters.
Drain the fuel tank.
Depending on what your plan for the tub is, remove all interior bits and cargo glass.
Remove the windshield. Cut the seal and you can save the glass.
Remove the body mount bolts.
Lift away.
Remove the radiator, battery, etc.
Lift away.
If you're not going the full restoration route...here's what we did while doing a simple body swap between two Pigs. You'll also have some wiring to disconnect. LIfted bodies off chassis with a two post lift.
should have included disconnect steering shaft
Can you show us a photo of the gantry crane you plan on using? Don't underestimate the weight of that body. It's a heavy biatch. Will you be using one or two chain falls?
Since tagging NG produced no results, here’s his thread for patina preservation
