2fpower
- Thread starter
- #121
Spent last night opening the harness up and pulling out the ABS and airbag stuff. Ended up being a good chunk of wires.
Now I’m trying to figure out what other wiring is extra that I can pull out. As I was doing the SRS system, I found two wires going to these “junction blocks” in the center area. I traced this back on the wiring diagram and it is wiring going to the seatbelt warning light system - if that matters. Anyway, the little cap plugs that go into them basically connect the wires, so I think this is some sort of junction that Toyota uses instead of splicing and soldering wires. I know I could save some space by getting rid of this, but I don’t really see it adding a lot of value. I can likely pull the wires for the A/C system as going to likely use the Hurricane system, but will wait until I have that in hand. Not sure what else that I can pull out. This car did not have power windows or locks, so not many extra wires.
So for interiror work, wiring, my next goal is to mount the steering column and pedals. I assume I use a standard pedal setup and cut out the clutch pedal????
