Cruisers and Co
Supporting Vendor
- Joined
- Mar 30, 2023
- Threads
- 3
- Messages
- 427
- Location
- Westminster, Colorado
- Website
- www.cruisersandcompany.com
We've been teasing our turbo kits for awhile now and they are finally available on the website!
In this post I hope to answer most questions that we have been receiving over the last couple months since we started teasing this. It's going to be a long post so bear with me!
First off for those of you that don't know me or our shop I'd like to introduce us. My name is Johnny Pryor, I am an owner of Cruisers and Company. We're a small Land Cruiser and Toyota 4wd shop based just north of Denver in Colorado. We provide a large range of services and are getting into producing aftermarket products. You can learn more about us here.
We're enthusiasts just like many of you and have been modifying our vehicles to meet our needs and this is how our Turbo came to be. My personal 80 (our test truck) is a 1997 LX450 and I've owned it since 2012. Fully loaded, 35's with 4:10's it is pushing over 7K lbs easily and the stock 1FZ was not cutting it anymore. We overland often and occasionally run harder trails such as the Rubicon. The truck gets driven long distances on the highway and swapping the engine was not the answer for me so we built our kit for it. The truck has been turbo'd for over a year now with two iterations. We've taken what we've learned between the two and put together a super comprehensive kit that covers pretty much everything for the OBD2 US Spec trucks.
Before we dive into what's included I want to give some insight and be completely transparent on how we have decided to launch our system. We are producing these in batches and only the allotted # of kits we have produced will be available for purchase and then they will be out of stock and it will be unable to be ordered until the next batch is ready. If you hop on the website right now you'll find it says available for preorder. We use Wix to host our website and to prevent more purchases than what we have on hand we have to list it as a "preorder" if we want to limit the # of sales to what we actually have in stock. Why Wix doesn't let "in stock" items fall to zero then go "out of stock" I don't understand, it's something were working through. They are in stock even though it says preorder. Everything in our first batch has been completed and we are just waiting on our finalized heavy duty boxes to show up this week so we can have a packing party and ship them!
Let's get into the fun stuff!
What comes in the box! I am going to list this from intake to exhaust by individual section.
Land Cruisers are not meant to be rocket ships and the Turbo truck is still not one but the modernization is very enjoyable and makes going to the mountains/cruising highways much more enjoyable which was the goal with this kit.
Happy Trails!
Johnny
Install video part 1
- Intake pre compressor using factory airbox - Silicone 180 coupler, an aluminum intake pipe with 3 ports on it (one for recirculation valve dump and then 2 ports for crankcase ventilation (one for stock hose, one for using our catch can system which is coming soon), silicone reducer, 4x T Bolt clamps, bracket to clock the MAF (intake piping works with dual batteries
- Turbo - Pre clocked Pulsar 6682, Internally gated with .5 Bar (7.25 lb spring)
- Intake Piping post compressor - Silicone 90, Silicone reducer, Cast aluminum 90 with port welded on for recirculating BOV and port pre tapped for wastegate reference, 4x Tbolt clamps, and silicone cap for throttle body port no longer used for crankcase venting.
- Spark Plugs - 6x Denso PK20R8 3127
- Recirculating Valve - Turbosmart Recirculation 25mm valve, 1" reinforced high temp silicone hose for plumbing to pre compressor, 4 tbolt clamps, vacuum source tee that also works well as boost reference spot for interior gauge, 3/16 barb aluminum 90, 3/16 silicone vacuum hose to connect vacuum source tee to turbosmart valve
- Water Lines - 2x premade AN 6 lines, AN 6 water fittings for turbo, AN 6 fittings to connect water lines to the two 8mm water bypass lines at the front of the motor
- Oil Supply Line - A Tee to connect to where the factory oil pressure sending unit is, adapter to AN 4, premade AN 4 Line, AN 4 Oil restrictor
- Oil Return line- AN 10 Turbo Drain flange, AN10 45 Adapter to clear the JPipe and orient the return properly, premade AN10 Return line, AN 10 Flange with hardware that mates to upper oil pan, template for where to drill and tap for oil return into upper pan.
- Exhaust Pre Turbine housing - JPipe with all new hardware and gaskets to connect to factory manifolds, hardware to mount turbo, stainless steel bracket to stabilize J Pipe with hardware.
- Exhaust Post Turbine Housing - 5 bolt flange to 3" v band adapter with stainless hardware with gasket, downpipe with m18x1.5 bung for AFR gauge, 1x extra v band and some exhaust pipe for the diyer to connect to factory exhaust or take it to the exhaust shop
- Heat management - Turbo beanie, 12" x 48" Heatshield Products 1/2" heatshield with template and stainless zip ties to wrap downpipe and AC line
Happy Trails!
Johnny
