As with all products there is always room for improvement. Our biggest challenge to date with the turbo's has been the J pipe. They are time consuming to make, a bit of a pain to keep everything lined up and difficult to keep from warping since there are a lot of welds on the J pipes. So far we've been able to do this since we are building each one on a head and we're going to continue building them that way but we knew there are better ways out there. We've kept each iteration of J pipe and I think we have finally got them to where they are easily manufacturable, incredibly strong, and fit perfect every time.
Our initial prototype V1 J Pipe (left) was a bit of a mess as we made it on the truck. We then found a head and were able to refine it and get the the angles worked out. The problem with V2 (right) was that all of the straight sections were cut by hand which meant the human error was there and every once in awhile would require cutting new pieces... Not ideal at all. It worked but it could be better...
To negate the human error we turned to a company that does laser tube cutting. Sent them the CAD files and got the straight sections lasered perfectly every time and so V3 (left) was born. These are really easy to weld since everything lines up every single time BUT....
We knew there had to be a way to cut the # of welds down!
SO... we laser scanned the best one we've made to date and went back to the drawing board. After some CAD and researching we figured out the pipes could be made in 3 sections to bring the # of welds down to 5. If you look and count the welds on the proto there are 15... V2 and V3 had 10. With V4 we've cut the pieces needing to be assembled in half, taken out the human error of cutting pipe, made it a uniform thickness and it just looks awesome! Really trying to make the best product possible. The pipes and flanges are thick allowing us to get really good strong welds, the cnc collector ensures a perfect platform for the turbo and allows us to tie it back to the head so that it's really locked in. Excited to get these built!
