Are these shocks long enough for the slee 4inch springs?
Probably still too short at full droop. I know Woody runs the 50mm Slinky’s on his 80 and he uses every bit of the 12” Travel Slinky shocks.What do you think about 50MM slinkies paried with the long variant of the BP-51's?
I'm a bit confused Adam. I have always been under the impression that the shocks on an 80 Series are what limits droop. Is that not correct?For those considering pairing the BP-51's with Slinky coils, be aware that the length of the BP-51 is too short to allow full travel of the Slinky coils. So you will either need to run some type of limiter for droop or relocate shock mounts so as to not damage the shocks by having them be the limiter for droop.
In a lot of cases you’re right Dan, but that isn’t ideal since it can damage the shocks. A lot of the suspension kits out there are set up in a way that makes the shock the limiter. Again, not the best limiter.I'm a bit confused Adam. I have always been under the impression that the shocks on an 80 Series are what limits droop. Is that not correct?
Make sure you give us an update. What springs are you running?I got mine today for my 92 HDJ81. Looking forward to the improvement in ride and handling. The 200k km old OME shocks were a bit past it.
The L shocks have been successfully used on 3-5" kits in thousands of application. Would it be nice if OME (and other manufacturers) made a 0", 1", 2", 3", 4", 5" shock? Of course, in the mean time we deal with what they sort as a "best" marketable offering. If there was enough demand for a L+ shock, they would absolutely make it. As for offering customer specified lengths, I don't see that happening anytime soon as demand for their existing offerings has their assembly going full speed. King and others can build a custom spec bypass shock exactly to your specs in the $3k range. The external bypasses will require additional modifications for clearance but you'll have to sort that.
For an 80 that still uses radius arms, it’s far better to have the front travel limited by the radius arm rather than the shock. So getting the right springs and shocks that are not the limiter in either compression or extension will let the suspension work properly and not risk shock damage.
The rear should be the same approach where the movement of the suspension links and swaybar should be the limiter of droop if possible.
So help me understand here, as far as I know the 80 only has the shocks as the limiter unless someone instal limiting strap. In most cases the suspension unloads fairly slow and gentle unless someone jumps it hard with 40 inch tires. Is there anything else on the 80 can act as limiter in stock onfiguration?
sway bars .. ?
True. The shocks are often the limiter. Can still cause damage to the shocks unless the shocks have internal bump type features designed to address that issue. Even with suspension that isn't violently unloading, the repeated unloading and bottoming out can cause damage over time. Typically in the form of damaged seals in the case of 80 shocks that are pin/pin ends. On shocks with eye/eye ends the shafts can break away from the eyes, or bend the shafts because of overcompression.So help me understand here, as far as I know the 80 only has the shocks as the limiter unless someone instal limiting strap. In most cases the suspension unloads fairly slow and gentle unless someone jumps it hard with 40 inch tires. Is there anything else on the 80 can act as limiter in stock onfiguration?
