Posting this in both 100 and 200 forums as this is a solution that works with both rigs.
ARB 2500 Awning. Yakima Mighty Mounts.
That’s slick. Are mighty mounts still easy to find? I’d heard they were being discontinued
Easy Woody, I'm pretty sure he isn't trolling. I think he was just posting a helpful thread of people in the same boat, looking also for solutions. I like your Yakima mounts, very inexpensive and seem to work well. I have an ARB 2500 and also found that other thread very helpful. I think we are all just helping each other here.Ah ha, I see you've found all the lame ways to mount an awning. Go troll somewhere else amateur.
Mighty Mounts on Amazon for $38. Stainless steel hardware from Lowes for like $10, 4 bolts, 4 nylon nuts, 8 washers.
Don't you want three attachment points with an ARB awning? I assume that's what ARB intended when they give you three sets of bolts with your awning...
ARB supplies 2 sets of mounting bolts. (6-6x20mm bolts and 6 nylon nuts) That’s 3 bolts for each of the 2 mounts. It is solid, not going anywhere, 3 mounts/attachment points would be overkill.Don't you want three attachment points with an ARB awning? I assume that's what ARB intended when they give you three sets of bolts with your awning...
I've been running a Sun Seeker and a Fox Wing for years on my 80 with two mounting points without issues. This seems like another solution for mounting an awning but it appears at least in your photo's the bolts are touching the roof rails?
Great to see another viable solution. The Rago mounts are still the standard IMHO as they mount to the rail leaving the crossbars open for attaching a roof box or moving to different widths without impacting the awning. The Rago also has a triangular mounting plate to the rail providing 4 points of contact to handle the forces the weight of the awning puts on the rail.
Toyota 4Runner Canopy/ Awning Mounts For Factory Roof Rail
I think this is a great solution if you already have the ARB mounts and/or you may want to take it down from time to time. For the price however, if you have to buy the ARB mounts plus the Mighty Mounts and the hardware, I think it would be easier and cheaper to buy the Rago mounts for $70 total which have everything included. I also have mine mounted all of the time with 2 mount points and it has been fine for months.
Thanks again for this, as it helped me mount my awning easily, and for cheap! I noticed that your bolt isnt threaded in far on the inside part, and it looks like it's due to you using the top hole instead of bottom hole. I am sure you have figured this by now, but here is what i mean, and i hope this helps other members as well.Posting this in both 100 and 200 forums as this is a solution that works with both rigs.
