I’m in the process of tearing out the dash and replacing it. Which allows all the fun of being able to look at all the craziness that has happened over the trucks life.
How does the a/c work? Wiring aside as I know that isn’t proper what is meant to be In that spot as the plastic climate control has a spot for something legit.
Appreciate all the help I get on here.
Rookie question, changed the exhaust and now it has a burning smell. I am assuming its just part of the process with new pipes but just want smarter people's answer to ensure it's not something more important.
What color floor liner you need? I have a brown in good shape. Message me if interested
Does anyone have updated part numbers for
LAMP ASSY, FRONT TURN SIGNAL RH & LH
LENS, REAR COMBINATION LAMP (only reverse light, old school 75 series)
Mine have seen better days and need to be replaced. Both seem to discontinued but usually smarter people than I have found updated part numbers that work.
Thanks
Let me know if you want the pins and plug part numbers as well...Thanks, I have looked on the partsouq to get the part numbers. Just out of stock or NA.
Awesome, I will look into those turning lamps.
Thanks
