FAQ 60-series FAQ
This is a permanent (sticky) thread which will attempt to categorize and post discussions on commonly asked questions about the Landcruiser FJ60 and FJ62 series trucks. I am NOT the expert here, but will be reviewing posts. gathering and combining information from members responses to questions posted in the Cruiser Tech section.
This should help owners and caretakers to access the IH8MUD braintrust.
Buying a 60 / 62
FJ60 or FJ62?
FJ 60 / 62 gas mileage
60 Series Paint Color Chart
Just bought an FJ62 - What's next?
Smog issues
Smog pump rebuilds and emergency fixes
Emission System demons
Removing Smog?
Why do I have to recurve my distributor after desmog
Silicone Air Injector Pump Hoses
Vac Hose Routing
Common repair / replacements
New seatbelt alternative using 79-series belts
Modify the fan shroud to make water pump or fan belt access MUCH easier.
Water in your floorboard? Repair your leaky rain gutters.
Poor Heater Performance? Look Here!
3FE Fuel Pulsation Dampner - may improve your MPG
Intake and exhaust
Where to find GOOD new vacuum hose
Tips for installing Old Man Emu Lift
Common Torque values
Oil Galley Plug Fixes
Rear lift gate support arm replacements
Hood shock conversion
Do your own alignment
Aisin Hub Rebuild-from the 4Runner Section
FJ62 Door Lock circuit breaker fuse location
Fuel or temp guage spikes and goes back down occasionally.
FJ-62 T-case actuator solenoids
FJ62 4WD Vacuum solenoid fix for cheap
Electrical
The A/C Amp Thread
fusible link
FJ62 Starter Rebuild Instructions
FJ60 alternator rebuild reference
Driver side front power window auto down relay
Power window permanent fix.
Electrical Gremlins
_____Specific Issue Here Read port #21 for the why.
Ignitor repair
Igniter Repair for Cheapskates
Temperature Gauge Calibration - How To
Tuning and problem solving
Camshaft discussion
Tuning 3F and 2F for better performance
Valve Adjustment on an "F Series" engine
3FE Specific valve adjustment tips
3FE Specific Timing adjustment (in the 80's forum)
3FE fuel supply problems
Carb Circuits - Aisin 2F FJ60 USA - Troubleshooting
Weber vs Asian
Overheating - what to do?
FJ60 Fuse Panel data
Reading 3FE engine codes
3FE top end engine mods
Charcoal Canister / High Fuel Pressure in Gas Tank
Chasing Vacuum Leak / Vacuum Understanding
Lubrication
Lubrication Secifications - 60 and 70 series Gas and Diesel Enigines
Engine oil choices for the 2F & 3F engines
Conventional or Synthetic oils - what do our members run?
The Oil Filter Discussion Thread
Oil pressure readings - senders and gauges
Automatic transmissions
Changing Tranny Fluid
More info on cleaning the filter and flushing the transmision
FJ62 Transmission Oil cooler install
H55F Toyota Manual Transmission swap into an automatic 3FE FJ62
Loose shifter automatic shifter fix
Loose shifter automatic shifter fix - permenant solution
Valve body install
$13 ATF temp "gauge"
Official "How long does an A440 last" thread
Suspension and Steering
The Front End Clunk Thread
Improved handling for a 60
Fixing common steering problems
When and how to rebuild the knuckles
Jim Phillips detailed front end (Birfield and knuckle) repack
Morgan's knuckle rebuild
FJ60 – FJ62 stock spring packs
Old Man Emu and alternatives
Old Man Emu Install with pics
Parabolic Springs - discussion and photos
Talking about shackles
OME or BDS?
Thoughts on SOA (Spring over Axle)
Extended sway bar and LSPV on a lifted FJ62
FJ60 hydro assist porting
Steering Box Reseal
Differentials - gears, lockers, etc.
Feedback on what IH8MUD Board members are running
How to modify a Vacuum shift 62 transfer case to manual shift
Wheels and Tires for a 60 / 62
Aftermarket wheels that work & part numbers
Rims and tires
Tires the iH8MUD members are running...
Engine and drive train swaps
My H55 swap thread
More power from the 2F - an alternative
Looking for a definitive guide for Vortech conversion for 60s
Bottom line for a Diesel swap in a 60 series
Installing an H55F Toyota 5 speed in a PRE August, 1985 FJ60
Installing an H55F Toyota 5 speed in a POST August, 1985 FJ60
H55F conversion parts list
Adapting the stock tach for use with a V8
Building a 2FE from a 2F and a 3FE
Split case ratios and Modifying a 62 vacuum shift case to a manual shift.
Popular modifications
Best mods under $50
Just bought a 60 Series Cruiser? Suggestions on 'must have' modifications
Long range gas tank
Dual Battery installs and battery isolation schemes
Maximizing performance of the stock alternator
Brighter Headlights for the FJ60
How to - Headlight wiring harness upgrade
Questions about wiring driving lights
Bed liner on the exterior
4 Runner brakes - easy bolt on brake upgrade
Sound Deadening
FJ60 Dual Alternator
Appropriate winch for 60 series
Getting rid of the exhaust crossover pipe (rock catching) on the FJ62 Exaust
Sway bar disconnects
Extra grab handles in a 60 series.
Very cool Under Seat Storage
Sluggish windows fixed for $40!!!! Dial-up grab a coffee
62 Power Window Help
2WD LOW t-case mod
FJ62 Headlight upgrade
4Runner Calipers, T100 MC, Rotors and Backing Plate Eliminator install
Holley Sniper Install
Tie Rod & Drag Link Information... Graciously provided by Kurt at Cruiser Outfitters...
(Not trying to advertise one business over another - This is just helpful information).
Tie Rod Thread Diameter and Pitch: 23x1.50mm
Drag Link Thread Diameter and Pitch: 21x1.50mm
We do have the taps here in the shop but not something we sell. Unless you are using them often it's actually cheaper just to buy new tubes which we offer here:
http://www.cruiseroutfitters.com/steering.html
6x Series Replacement Links/Tubes (OEM Toyota)
Tie Rod - Fits 1980-90 6x Series LHD/RHD - Part# TRET69105 - $97.50
Drag Link - Fits 1980-90 6x Series LHD/RHD - Part# TRET69055 - $121.50
6x Series Replacement Links/Tubes (Japanese Aftermarket)
Tie Rod - Fits 1980-90 6x Series LHD/RHD - Part# TRET69105JP - $67.50
Drag Link - Fits 1980-90 6x Series LHD/RHD - Part# TRET69055JP - $87.50
Please give us a call if we can further assist with parts. Thanks!
Kurt
801-563-1277
Just checked and I am having the same issue.
Tagged the wrong woody. Not sure what his exact username is.
@Mace
okay, I'll start on it tonight.
HEATING and COOLING HOSE REFERENCE
Adding advice on whether I should buy a land cruiser as a young person with no experience, Fj60 vs fj62 vs 80 vs 100 series......
short answer: It DEFINITELY depends. A no for most people, and even though i was ”most people” who didn't know s*** about cars, I was one of them but gutted it out, sacrificing a ton of my life and time to learn. Good thing I didnt have a life before this :)
Should I buy an Fj60
Odd request, but does anyone have a good 60 series dimension diagram, or a link to a site with accurate dimensions? Something like this is what I'm looking for, but with legible numbers. I can't quite make out the numbers on this image (it also appears to be in metric measurements, non-metric measurements would be ideal).
Odd request, but does anyone have a good 60 series dimension diagram, or a link to a site with accurate dimensions? Something like this is what I'm looking for, but with legible numbers. I can't quite make out the numbers on this image (it also appears to be in metric measurements, non-metric measurements would be ideal).View attachment 3982031
I'd like one for the FJ62
Add Head Lights ON, Ignition Key OFF warning buzzer.
