It's my understanding more advance helps with efficiency at altitude, is that accurate?
If the vehicle is to be operated mostly at high altitude, say above 6000', would the stock curve be a better choice on a totally de-smogged 2F?
Would this configuration remain effective at low altitudes if premium gas was used?
Keeping the stock curve and changing your fuel with altitude isn't going to be a great solution. Without EGR, the problem isn't that the stock curve is too much advance at all engine speeds, but rather that there's too much at some RPMs and too little at others. That means if you adjust the timing for one part of the range, it'll run okay in there but poorly in elsewhere; you either get pinging under some conditions, or you have to set it so it won't ping at all, which means it'll be running without enough advance through most of the RPM range, and only 'just right' in a couple of particular spots. Result? Smelly exhaust, less-than-ideal MPG/power/torque. It'll run, though (mine has been desmogged with a stock distributor curve for 7 years now), just not ideally.
Now, re: altitude, I've found that my setup runs about the same (reliably 'okay') from sea level up to ~7000 feet, and the timing not being advanced enough up at 7000 probably has a lot less effect on the running than there only being ~78% as much air at that altitude (since it doesn't have any sort of turbo to help with that).
Being not such an old thread I'v decided to post my question here. Is there any way to tell if my dizzy has been recurved? The truck was de-smoged by the PO who did a good job, but I have no idea if he did this or not, and I definitely have some issues with pinging and power loss at certain RPS's (though only after I'v been on the highway for a while, so I don't know...).
Thanks!
Clark
@distributorguy, Jeff can recurve but no vac adv pot rebuilds. @FJ60Cam i ‘think’ was going to have him put a non oem vac adv single diaphragm on his. I’m curious myself if that went well?I think @NeverGiveUpYota has another guy who is doing recurves and vac diaphragm rebuilds too
I'd like to know that information as well. My pig, Bucky, has a bad primary vac pot. Right now it's just running mechanical advance with a little boost from the secondary diaphragm. I'd like to source a new vac pot one way or another.Darn, sorry! I’ll find the thread and the name of who told him.
