Suggestion for FAQ - Common Torque Values
lovetoski
Once you do a number of repairs on your cruiser, you prolly remember what to do. If you are like me though, the exact torque values might not be firmly in memory. So, I was thinking that a useful FAQ would be a list of common torque values.
When the list is done, I was thinking to post this as a pdf to facilite saving and printing. Thoughts?
This is NOT a how-to, it's only a reference table of how tight to turn the various nuts/bolts.
I'm happy to look up the values, but want to get input as to what to include. Here's a starter list...please feel free to add
Front Axle
Freewheel Hub Cover - 7 ft-lb
Freewheel Hub Body - 23 ft-lb
Front Hub Bearing lock nut - 58 ft-lbs
Knuckle Studs - 71 ft-lbs
Spindle Mounting bolts - 34 ft-lbs
Brake Caliper - 65 ft-lbs
Brake Hard Line - 11 ft-lbs
Tie Rod to Knuckle Arm - 67 ft-lbs
Relay Rod to Pitman Arm – 67 ft-lbs
Relay Rod Clamp bolts – 33 ft-lbs
Steering Damper – 54 ft-lbs (both ends)
Sway Bar End Links - 13 ft-lbs
Sway Bar to Axle - 9 ft-lbs
Drive-Shaft/Companion Flange - 54 ft-lbs (4 per end)
Differential Carrier Nuts – 34 ft-lbs (10 total)
Diff drain/fill plugs - 36 ft-lbs
Spring Center Bolt - 36 ft-lbs
Spring Pins - 67 ft-lbs
U-Bolts - 90 ft-lbs
Shock - Upper - 19 ft-lbs
Shock - Lower - 70 ft-lbs
Rear Axle
Rr Diff Cover - 9 ft-lbs
Rr Diff Carrier Nuts – 34 ft-lbs (10 total)
Drain/fill plugs - 36 ft-lbs
Drive-Shaft/Companion Flange - 65 ft-lbs (4 per end)
Spring Center Bolt – 36 ft-lbs
Shackle Pins – 67 ft-lbs
U-Bolts – 90 ft-lbs
Shock – Upper – 47 ft-lbs
Shock – Lower – 27 ft-lbs
Sway Bar to Axle – 9 ft-lbs
Sway Bar end-links – 9 ft-lbs
General Tune-Up/Fluid Change
Transfer case fill/drain plug - 27 ft-lbs
Spark plugs - 20 ft-lbs
Oil Drain Plug - 20 ft-lbs
Valve cover - 78 inch-lbs
Misc
Wheel Lug nuts - 90 ft-lbs
Thermostat housing bolts - 156 in-lbs
Waterpump to block - 27 ft-lbs
FJ62
Transmission pan bolts - 61 in-lbs
Head stud torque on 2H motor? Help please.
I have no clue - and no appropriate manuals to refer to. However the diesel forum has some folks on it who could help for sure!
Can you add the torque for the engine side cover & oil pan?
Ya, good idea! Can't find the value for the engine side cover though? Looked in the engine manual and Haynes too.
The FSM says 53-104 in/lbs for the oil pan bolts. I torqued mine to 85 in/lbs.
I couldn't find anything either for the side cover. I am guessing it is a little less than the oil pan bolts.
Ya, I was looking at different but similar bolts and was guessing similar. I'm going to do a few updates to the original list and repost. Thanks again for the sugggestions.
Have you reposted this somewhere? I assume the tranny drain/fill is the same as the diffs but I can't find it in the FSM.
I didn't find it either.
Are we sure about the Torque settings on the Waterpump to block values?
I'm looking at the FSM and it calls for 13Ft Lbs.
Can anyone verify this?
:confused:
"Are we sure about the Torque settings on the Waterpump to block values?
Can anyone verify this?"
I just did mine a few weeks ago, and yes it's 27 ft-lb.
"Thermostat housing bolts - 156 in-lbs"
That seems correct, but it may be simpler to write 13ft-lbs. ;)
Yep, you're right....I was looking at a different FSM for a different Toyota Vehicle.:doh:
Anyone have the torque values for the five bolts that hold the intake manifold to the exhaust manifold? there are three bolts on top and two on the bottom.
Thanks!
A440F Transmission Pan?
I have the FSM's but can't find a torque value for the five bolts that bolts the intake to the exhaust manifold. There are three on top and two on the bottom. Anyone have them?
How about the EGR tube?
Thanks!
How about the EGR tube?QUOTE]
Ditto for me- J-tube torque value. It's hard to find some of this obscure info in the FSM.
