FJ60 Dual Alternator
Eugene, OR
Website
www.wagongear.com
The Overly Complicated Approach to Dual Batteries
Desmogged 85FJ60
Alternator bracket from a 62
OEM;
Alternator
Fusible Link
Wiring Harness (part of it anyway)
Ignition Relay
Water Pump Belt
Non OEM;
106mm Pulley
8mm spacer for tensioner bolt
On an FJ62 the alternator goes where the FJ60 smog pump sits. The 62 bracket bolts directly to the 60 block and body mount.
The bracket needs to be cut a little to give the alternator enough room to swing.
The belt from a 62 will not work because the 62 block is shorter, so the water pump is closer to the crank, sooooo the belt is to short.
The 60 smog pump pulley is much larger than the alternator pulley and they are not interchangeable.
A 44” belt will fit just fine with the stock alt pulley, but it is hard to find and it is NOT OEM TOYOTA. Which when it comes to belts is very important.
So I sourced a larger pulley from an alternator shop and modified it to work.
106mm O.D. 17mm Bore. 16mm belt groove.
That is pretty amazing. How did you route the cables from the second alternator? Did they go directly to the second battery?
The parts are all interchangeable and OEM so there are fewer spares to carry. (ultimate redundancy)
I ran a battery cable over to the main battery to facilitate self jumping (eventually I will put a battery switch on there) You can see the overflow bottle has been moved to the fender where there is already a nut of the same size. And I used two sexy new battery trays from stainlesstrays.com.
All finished.
Did you reply before or after I posted the wiring diagram?
The wires travel exactly the same as they do in the OEM setup, just in a different one.
Sorry. That was a premature reply to your post.
Definately an original solution to the age old problem of not having enough power.
looks good.
I'd reroute the air intake.... higher is better than lower, but otherwise, a very elegant solution all the way around. Thinking about doing something more or less similar in my HJ60.. but no smot pump location to take advantage of :(
Cool. A couple of considerations to think about (and maybe you addressed them or they are inconsequential): #1 Does the larger diameter pully spin the alt fast enough to generate good voltage (mostly at idle)? #2 Is having the alt underneath the PS pump a good idea considering that it will eventually leak?
Otherwise, very nice. Wish I was adept in the way of the electron. I have trouble with basic wiring.
Way to drag up an old thread.
In this case I happen to have a certain affinity for the topic at hand, so I don't mind..........:cool:
Sandcruiser, I'll trade you my dual alternator for your HJ. :D
The Air intake comes out at the same point as stock, right behind the headlight. Snorkel someday.
RredFJ40, I was concerned about the pulley size, and at a low idle the volts are a tad lower than at speed, but the motor only needs to be at about 800rpm before that alt takes full effect, really not that high.
PS pump leaking on an alt is better than leaking on a smog pump, if it does leak on it and happens to effect it, no big deal, I have 2 under the hood now.
I suppose it is no different than having the smog pump in the same location.
:cheers:
P.S. After field testing this for the past few months,........... I really like it.
All things electrical just seem to have more juice/faster response and having the high watt headlights run of the other battery is great.
Not even mentioning the whole fridge thing, which just kicks serious a$$
that looks like a good setup. Sure make sense if you have a electric winch and or high powered lights / radio. i've been thinking about the same thing.
You running two 55amp alternators?
I routinely run second alternators in that location. One is even just there as a replacement for the smog pump so that the belts all work right, not even wired in yet...
But I've never done it quite that cleanly... ;)
Mark...
