TempGauge 101
Attached to this thread (temperature-calibration.pdf) is some information about testing and calibrating the stock FJ60/62 temperature gauge and sender. The method described is fairly well known and can be found elsewhere on the Internet if you search around. I'm not breaking any new ground here, but since there isn't a specific temperature calibration thread here on mud for the FJ60, I thought I'd post one up.
Also there is information about the behavior of the sender at higher temperatures and how that impacts the needle position on the gauge dial. A copy of my logs of a tested new sender is included as well.
The information here is presented as a downloadable single 5MB pdf file due to the number of images and the amount of information included.
Be sure to check out the thread "Burping the sender" before trying to calibrate your temperature gauge.
Also for an in-depth analysis on the internal workings of the 60 series temperature gauge, check out @Spook50 s excellent write up below.
Permanent fix (in progress): Fuel/temp gauge spiking (pics, not dialup friendly)
Thanks goes out to @HemiAlex for providing some valuable FJ60 gauge feedback>
Tags:
Temperature calibration
Temperature gauge calibration
Temperature sender calibration
Overheating
Burping
Engine temperature
Engine temperature gauge
Temperature meter
Coolant temperature
Hot coolant
Engine runs hot
Thermostat
Cooling system problem
Coolant replacement
New coolant
Draining radiator
Air in cooling system
Tags:
Overheating
Burping
Engine temperature
Temperature meter
Coolant temperature
Hot coolant
Engine runs hot
Thermostat
Coolant replacement
New coolant
Draining radiator
