Reference:FJ60 Alternator Rebuild Bearing Numbers
Standard Motor Products
voltage regulator= VR-160 $20
brush set= JX138 $4
:cheers:
Cool,
IIRC
Toyota VR =$38
Toyota Brushes =$11
That is a pretty big savings.
Do you think the quality is on par with the Toyota? Especially the VR?
I just get a warm fuzzy feeling knowing that my parts have a TEQ stamped on them. ;p
Does anyone know the part numbers for an FJ62 alternator?
Bearings and brushes? Regulator?
Bumping a great but old thread.
Can anyone pls point me to what diodes are suggested to rebuild an fj60 alternator?
I assume that if I'm doing the bearings, brushes, and voltage regulator then I should also swap the diodes for good measure?
Really surprised/disappointed I can't score a decent plug and play replacement for a decent price within a timely manner (within a couple weeks). So figured I'd swap out some internals in the mean time.
The diode board is (was?) available from Toyota for $300.
Or you can get a reman alt from rockauto for $60.
More Information for ACDELCO 3341599
@FJ40Jim thanks for the solid lead/advice! Much easier and economical than a rebuild.
I checked it a few days ago when you initially posted this up and they were out of stock, I suppose a wave of Mudders followed your advice...
Randomly gave it another shot this AM and was able to get my order processed. Hopefully it will go through. Keep you guys posted.
EDIT: have tried several time to purchase and after a few days the order gets cancelled due to lack of inventory.
Anyone have a current source? I bought the brushes and voltage regulator and will likely crack open my existing one.
