- Joined
- Sep 9, 2004
- Threads
- 186
- Messages
- 11,059
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
Cheers
Damn guys, super nice. Now wait till ya go to put the right foot into the floor, THAT will be worth the wait!
And $.I like how this thread takes obstacles related to customization in stride. Setbacks like reworking legs on sliders or finding the right oil pan would be disheartening to me. But SNLC and JMLockwood have the right attitude for stuff like this... focus on the long haul without getting impatient.
And the winch. I ordered that 12.5 Comeup thinking it would fit no problem. And it does fit but not great and doesn’t mount up so well. @SNLC was going to fab up some mounts but I decided we would just get a Warn M12000 as that should bolt up with no mods.I like how this thread takes obstacles related to customization in stride. Setbacks like reworking legs on sliders or finding the right oil pan would be disheartening to me. But SNLC and JMLockwood have the right attitude for stuff like this... focus on the long haul without getting impatient.
Don't forget that the matching pickup/strainer needs to be switched also. There are urban legends of people not switching the pickup and destroying the engines. I have used the HZJ105 sump and pickup for my 80 conversion as the 80 series were out of stock and I think that they are not made anymore. You need to change also the oil dipstick.So a little more info for anyone doing this swap in an 80. This applies pretty much just to the FTE since the other 1Hx platforms came in the 80-series and you are unlikely to be swapping in say a HZJ79 1HZ into an 80-series.
This is in regards to oil pan. The FTE came in HDJ100’s and HDJ78/79’s which the 78/79’s are an Aussie only Cruiser, worldwide. FTE is common in 100’s though worldwide but no it didn’t come in the 105. You would think the FTE in the 78/79 would have the same pan as the 80-series 1HZ, 1HDT, 1HDFT since it is a solid axle Cruiser with almost identical suspension to the 80-series. A 70-series 1HZ pan should work too for that matter and the 1HZ in a 70-series is probably the most common setup of any Cruiser ever made. So the pan is easy and cheap to get even in OEM form.
However, while the pan from the 100 FTE or the HDJ78/79 or for that matter a HZJ75 pan will all interchange onto any 1Hx 80-series engine (and vise versa) but they won’t work in a swap. Matter of fact, the only pans that will work in a FTE swap into an 80-series is the 80-series 1Hx pans.
Last week before we installed coil springs we set the front axle down on the bumps. The pan on the FTE now doesn’t clear the tie rod at max compression and this is a HDJ101 (JDM spec 100) pan. We also have HDJ78/79 pan in hand and also a 70-series 1HZ pan. Lastly, we have an FT pan from an 80-series. It (80-series) is the only pan that clears.
So there you have it, the 1Hx oil sump pans for an 80-series are specific to the 80-series and you need one of these if swapping an FTE into an 80-series.
12101-17170 oil sump
15104-17060 strainer
15301-17060 dipstick
Jorge
I think it’s probably fair to say there is a lot that happens to this truck that doesn’t make it’s way into the build thread. It’s really more of a way to document everything I’ve had done to the truck. Not really a tutorial on how to make this swap happen.Don't forget that the matching pickup/strainer needs to be switched also. There are urban legends of people not switching the pickup and destroying the engines. I have used the HZJ105 sump and pickup for my 80 conversion as the 80 series were out of stock and I think that they are not made anymore. You need to change also the oil dipstick.
Jorge
I really like them! Have had them on trucks in the past and have one on my 200 series. I just felt like we really had no reason to fab the bumper if we didn’t have to do that. There has been enough of that already. But yea we can do a deal for sure. I’ll message you.Let me know if you want to unload that Comeup. I had success with them in the past.
And I'm sure shipping to the other side of the building will be reasonable.
Warren or go home
