Drain at the top, unless that's the feed?
Ha, the second tapped hole?
My turbo has that too. Had a hose on each, joined with a t before the wastegate....seemed a bit much.
Yupp, I’m gonna do the invisible rubber mat trick too.I had a rear storage bin like that in my old 42 when I had an aqualu tub. It was awesome. I had a heavy rubber mat cut to fit between the wheel wells.
Killed the rattles and made it totally invisible to the dbags peering in for souvenirs.
Toyota must've had a mountain of extra PTO gears to get rid of
The problem here is my hand brake on the floor. Exactly where my pto level wants to be.Toyota must've had a mountain of extra PTO gears to get rid of
I gotta do something with mine. Tripped over a Braden? PTO winch I bought 15 years ago yesterday.
If you have to take the shifter knob off watch out for the tiny ****ing screws. I modded the bracket to get the handle further away from my leg when driving too.
Sticks out a fair bit otherwise. Or at least my RHD 60 bracket did. Maybe there's different ones.
That's the unfortunate reality of working on a modified rig... I had been planning on installing a 6500 lb Matador PTO winch on my 40 for a while. However, my exhaust system, radiator, and engine mounts are all in the same area that the pto shaft would need to go through. I know that with some very careful planning and modification I likely could a fairly oddball and rare winch to work. In the end, I decided a 8274 for $330 would be more affordable and easier than tilting at that windmill.Well I ran into a road block yesterday. Not the drinking and driving type but..... Whoever did this 3B swap didn't have the proper rad support and did a crappy job at making one. Long story short, the bracket holding it up is right in the way of my pto drive shaft and the through-hole I have to drill for it. So now I have to pull the whole rad and support to reconfigure this mess. The fan was rubbing the shroud anyways soo time to fix this issue.
It’s a 40 series top. This winch was from a 60. The engine swap was t done to Toyota spec. Seems way more forward than stock setup.Would using a 60 series top cover for your transmission to move your shifter back 3.5” to get it out from under your heat make things work better? Or is it already a 60 cover and the transmission & engine really far forward?
Usually I only see heaters modified that way when there’s a V8 under the hood.
