Whoops I did it again (17 Viewers)
And the battle continues
edit
Incase you forgot. Doors have two hinges. Lmao
Oilite bushings. drill 'em out slightly oversize and never have trouble again
Cool! Amazon has a huge selection. I'll go measure when it get light out and order some up. Cool hack.
FF413-2 Oilite Bushing
Flanged bushing
Told "5/16 id 7/16 od"
Bushing 0.3135 id
Bushing 0.4395 od
9/16 od Flange
1/16 flange thickness
I drilled the hinge out to 7/16".
Installed bushings
I used a vice to press them in, and a file to thin the shoulder for a perfect fit.
The hinges now work better than new.
I did a similar thing with some I found that were getting chucked out at work.
I spun a bit off the flange on the lathe and drilled them out slightly.
I did windshield hinges and the doors. Soooo much better.
White spooge is neverseize :lol:
I rarely found any good stuff when I was at Yeehaw. The department I theoretically work in now rarely throws out a paper clip and you get all kinds of neat sh!t ;)
It’s a very worthwhile upgrade. I never had OEM bushings to compare them to, but they bronze bushings work great and are well worth the effort.
OEM were thin plastic. Disintegrate if you look at them wrong, probably first time the doors get removed half of them get lost.
Heater core before and after. Well, light particles can pass through it now. I can’t remember? Is light thicker than hot air??? Lol
Roll cage for midgets or tube stretcher?
It’s 2” of slightly under. Sprinkle pipe is 1.9375 so the scrap yard should have some.
Looks like someone got lazy and just drilled straight through and probably sandwiched it with a carriage bolt. Support rail was squashed on the driver side. I cut it out and replaced it with 1/8th steel with a bolt welded on the blind side.
Almost all together. I need a shop i can park all my cruisers in. My toes are cold.
Definitely! My wood stove is 6 feet from my shop so….. work/warm up.
Well…… who ever did the engine swapped used the tranny hole for the OM transmission which was about 2” further forward than the h55 hole. Not in the bandeirante. So instead of hacking the engine mounts off, transmission, new drive shafts. I decided to modify the heater. Minimal heat for the toes now but these weren’t really designed for comfort.
Slowly deleted the old heater core, cut new holes for the Canadian blower motor. This is truly becoming a hybrid. Some more plumbing and window defrost vents to be cut. So far it’s still a win. 3 steps forward, one back.
All the forward gears are touching the heater core but should still be fine.
