Well, I started out to repair the odometer on my 76 FJ40. When I dissembled the odometer I found the typical wax substance that was left behind after all of the volatiles evaporated. This stuff was so hard in the cold weather (+15 to +40F) that a plastic pin on one end of the long geared shaft had sheared off. I was able to replace this with a 3mm steel pin and reassemble the odometer. Works great.
But the really interesting find occurred when I was reassembling the instrument cluster. Out of curiosity I measured the resistance between individual pins on the circular connector and the copper traces on the printed wiring board. I did this because I noticed that these pins are just pressed in place, not soldered. I have designed and built many electronics devices over the years and pressed pins into printed wiring boards become troublesome over time, esp 37 years. Most of the pins measured around 20 to 35 ohms just between the pin and the copper at the base of the pin. Depending on the current following through these pins/copper trace interfaces, substantial voltages can be dropped at this interface reducing the current flow which will effect the gauge measurement - like the oil pressure gauge. The end result was that I cleaned the pin interface with liquid acid based flux, neutralized the acid, then carefully sweated (soldered) each pin (only at its base) to its copper trace. The resistances are now zero. My oil pressure gauge indicates about 10% higher.
Not sure if this has ever been covered before, but I thought it was worth mentioning. Results may vary.
I was once "The King of England" and that was a problem.You're stuttering Colonel (double post) .... but thanks.
esh where is that ? cool pictureWent and got it stuck under a tree (for a short time...)
It is 60F and sunny out, should go drive it.
Finally got it registered and insured....$380.80 year for $48K coverage...
Finally got it registered and insured....$380.80 year for $48K coverage....took it wheeling on the plateau, did 37 miles on a mellow trail, great flex and very quiet. Thanks to all who commented along the way...
Insurance company?
Skillet said:Painted my bezel from white to black...the roll cage and wheels are next.
It is already so far from stock, it really does not matter anymore...
Hey way off subject but I'm selling my off road trailer that looks to be about the same exact color as your rig and close to burnttoastburgo as well. What is your color called? The trailer is Hummer sunburst orange.
