What have you done to your Land Cruiser this week? (40 Viewers)
I have driven and been in several and had never noticed any interference or inconvenience, however when we initially tacked mine together to confirm clearance of the doors, window cranks, hardtop bolts etc. I became a little concerned, especially since this is a 78’ and later 40’s have slightly wider doors.
After trail riding all weekend, getting in and out what seemed like 100 times, I never adjusted my driving position or felt it changed the way I got in or out or operated the clutch. Visually tight yes, but not functionally in any way I noticed.
Good info to have. Thanks for the picture.
I’ve been in few older Rigs with a full cage and hated climbing around them. I always wondered if the metal Tech was the same way. Compromise foot room for safety.
I wondered if there was a solution like the Jeep guys figured out where they made a plate that ran down the dash.
My experience is similar. Welded up the MetalTech cage with the A pillars as close as possible to the doors, but so they still close. The bottom of the A pillar is close to the clutch pedal; you quickly get used to feeling the A pillar with the outside edge of your foot when you engage the clutch pedal.
New shoes for my rig this weekend! Next will be new wiring harness and new exhaust. SBC350 4 spd. Not a purist but having SO much fun with it!!
Really? Which way wider?
Yes, they (the ones with the more modern removable door panels, not sure what year that started) are wider to the inside.
half inch or so "thicker" from the outside to the inside.
Which doesn’t seem like much, but when you are accommodating both the door panel and the ability to crank the window up and down, it requires careful placement, but is eminently very satisfactory solvable!
If you look you can see where later doors bulge out just below the door panel.
I've been using these for years now, occasionally the mess misses them and I gotta mop, but definitely worth the $10 they were when I bought 2:
I had an HVAC unit replaced last year and noticed they were hauling off the old drip tray and snagged it.
Is perfect to rest under a 2F and to also use under axle rebuilds etc., nice for catching fluids and fasteners!
Love coming home to find cruiser parts waiting for me. Haven't had period correct turn signals for many years. These will be swapped in over the weekend. Thanks City Racer!
A few Pre GSMTR mods! MetalTech Family cage with single stage gray paint over epoxy primer.
View attachment 3352262View attachment 3352263View attachment 3352264
Everytime I see one of those cages I want one a little more. MetalTech makes such a good cage... I want one.
I've been coveting their Jackson cage for years. Seems way less popular than the family cage, but I like that it keeps the original "lines" and that, with a little modification, or an adapter bracket, you could probably keep the jump seats too.
Maybe it's a regional thing, but in the southwest I've seen way more Jackson cages than Family cages. I bought my Jackson kit after seeing several others IRL.
Certainly with the family cage there is some liberty in design and assembly.
I really like the standard design and the Jackson cage, but wanted the family cage to accommodate a full bikini top.
As a deviation from most, I opted to keep the rear supports parallel with the ground and as an extension of the front bars. I have aluminum boxes that I am mounting on the fender wells for lockable storage.
Has anyone tried to fit an OEM style soft top over the family cage? It almost looks like it might fit.
That is a good question, probably attainable if the cage is put together with that in mind.
Surely someone has accomplished or at least tried.
