What have you done to your Land Cruiser this week? (48 Viewers)
Fixed weatherstripping
Had two barbs brake on my separator. Picked up a couple of brass barbs at the hrdwr. store. I cut the old plast
ic barbs off with a razor knife then CAREFULLY drilled out the holes,and threaded the barbs into the plastic. I ran a bead of JB Weld around the threads . I'm happy with the way it turned out.
Had two barbs brake on my separator. Picked up a couple of brass barbs at the hrdwr. store. I cut the old plastView attachment 1632149 View attachment 1632150 ic barbs off with a razor knife then CAREFULLY drilled out the holes,and threaded the barbs into the plastic. I ran a bead of JB Weld around the threads . I'm happy with the way it turned out.
I hope to remember this the next time I see someone looking for a separater because of broken nipples. And I hope you will update how this holds up.
Did some last minute checks for my upcoming trip to DV. Found both my rear motor mounts were just starting to loosen up (if you can rotate the puck with a firm grasp, it’s still loose)
99% of the time when a front mount breaks, it’s because the rears were not tight enough. The other one percent: sudden impact!:eek:
I done tore mine apart pretty good...
D
I took it for a legit shakedown run now that the turbo is complete. Was only seeing 6lbs of boost it should be at least 10lbs. The driving vidfeo was choppy so i just attached a video for sounds haha.
Still just downpipe on it no exhaust. Ill get to that sometime...
Then while changing the body mounts I noticed that the fuel pump was starting to leak out the weep holes. So today i got a nice gift from City Racer.
And Installed
JP
Put some OEM door parts together, new wipers, felts, and runs.
