Spring bushings were slightly overdue for a change. Along with leaf packs fresher than mine, new OEM shocks, got an inch lift and a vastly improved ride.
Machined an adaptor for my single barrel carb so I can use the air cleaner I obtained. Might keep looking for the right year, but this way I can swap carbs if need be.
What's the trick to dealing with the rivet heads? Will be doing mine sometime this year (I hope).Time to sand hi build primerView attachment 1635138My orange peel
Never used guide coat, figured I’d give it a whirl
Almost there. I like the guide coat.
Did a full CLR deep clean last week and then did a boiled linseed oil rub
The difference is remarkable. Tons of work but the old Goat has a nice protective coat on it now
In all my years of woodworking (57 years) I have never heard of using BLO on metal. Can't see that it would last since it can't be absorbed into the finish.
You might want to look for Owatrol oil.I think it’s a new “fad” with the Patina vehicles. It’s not supposed to last forever, I’ll have to revive it after some time. The guys I was reading on the interwebs were saying 3-4 months if you leave it in The elements
Also,Note to self. Mask off the gutter before spraying guide coat. The guide coat over spray is not a joy to remove from gutter
My gutter channel is in excellent condition so I left it. I believe emac has been in some rivet discussion’s. Perhaps search “posted by: emac” search term “rivet” or “rivet tool”
Another good way to find mud threads is search from google.
Example:
“rivet gutter site:ih8mud.com” if you change out your keywords you’ll get different results. For instance you could also add these words into the mix (buck, squeeze, sealer, cap, channel)
