What have you done to your 100 Series this week? (56 Viewers)
And fabbed some shock protectors for the lower shaft, mounted to shock mount bolt.
^ Nice. How many gallons and where is the water hose going to run?
Completed some interior and engine bay detailing.
Installed new hood struts.
Installed new cabin air filters (old ones looked like the originals!).
I'm still building a list of prioritized PMs.
11 gallons seems to be the right fit for the space I had. There are a few water hoses- three at 1/2 inch diameter and one larger 1 1/4 inch. Bulk water entry will be the 1 1/4 and the other 2 for the circulation to the heat exchanger and last one for intake into the tank under pump power. I will finish it up and post better pics; just need to paint skids up and finish sown connections.
Interested to see the final product.
This week, I read codes, swapped around coil packs, erased codes, started and got new codes, cleaned the MAF, erased codes, started and got new codes...
coil packs are dead :bang:
Re-indexed my rear wiper which was sagging. Over-indexed since the visibility through the lower portion of the window is blocked by the spare tire anyway.
Before:
Simplest fix ever. Remove this 10mm nut:
Done.
That's exactly I what I have to do. My wiper has sagged the same.
Messing around with interior lighting
Makes a huge difference. Also installed one of these LED strips under the bonnet. Should come in handy
...via IH8MUD app
New rotors with OEM pads and all new bearings, seals, etc. E brake adjusted and front end alignment capped off the garage time.
...via IH8MUD app
Ha, without coffee I sleep.
I need at least four holes cut out. I may go up next to the AHC controls, or where you put them.
...via IH8MUD app
Who makes that USB/DVM panel assembly?
Thx
This 3 switch mount would fit where I installed my 2 switches, but it would be right up against the bottom of the t-case shifter. I was considering this, but I didn't have a need for a third switch.
...via IH8MUD app
Very cool, not sure I need more after the pfran swap, but this is awesome.
